When you cut your s...
[Closed] When you cut your steerer
[#3913022]
Do you leave space for a 10mm spacer on top of stem? Or **** it and cut it right how you want it?
Posted : 25/04/2012 8:06 pm
You don't have to leave any space for a spacer. However, a short steerer can affect how re-sellable the fork is 🙂
Posted : 25/04/2012 8:07 pm
Road fork so unlikely to be reselling...
Posted : 25/04/2012 8:08 pm
I'm a frame-shuffler so yep, I leave some extra.
Posted : 25/04/2012 8:10 pm
I've got a custom frame so cut my forks with no spacers above or below.
Posted : 25/04/2012 8:13 pm
 loum
If its a new build, you'll know if its right after a test ride. I wouldn't cut it down fully yet.
Posted : 25/04/2012 8:19 pm
If its a carbon steerer a lot of them will be void for warranty unless run with a spacer above the stem. It makes surer the stem is clamping the steerer properly.
Posted : 25/04/2012 8:25 pm
Tis carbon and never knew that. And am paranoid about my forks failing on some descent.
But the spacer on top does look crap.
Posted : 25/04/2012 8:35 pm
See rule 45:
A maximum stack height of 2cm is allowed below the stem and a single 5mm spacer must always – always – be stacked above. A “slammed down” stack height is preferable; meaning that the stem is positioned directly on the top race of the headset.
[b]ALWAYS[/b]
Posted : 25/04/2012 8:39 pm
Single 5mm spacer purchased
Posted : 25/04/2012 8:41 pm
