When would you use ...
[Closed] When would you use Pro Pedal 2 ?
[#4004557]
Have an RP23. Sag at 25%
Currently don't use pro pedal, feels good on descents, a little bit wallowy on general trails/ up hill.
If I were to use pro pedal 2 all the time (set and forget) what would change ? (good and bad)
Anyone doing what I've suggested? Thoughts please.
Thanks
Posted : 24/05/2012 10:08 am
Orange 5?
Posted : 24/05/2012 10:13 am
Yep, it's an orange five.
Posted : 24/05/2012 10:16 am
depending on the tune of your RP23, try running more sag and more PP. I run 35%ish sag and PP set to 3 - performs much better than fully off with less sag IMHO.
This is on an Orange Blood.
Posted : 24/05/2012 10:20 am
On a single pivot such as the 5, I would leave it off for everything apart from the longer climbs.
Posted : 24/05/2012 10:24 am
It's an XV can (not xxv) with 225 velocity, med Rebound, med comPression tune
(if that helps the techy guys)
Posted : 24/05/2012 10:28 am
LOL On an orange five I think I used it on 3 all the time except for fast descents. Then changed the bike.
Posted : 24/05/2012 10:32 am
TheSwede -
Member
LOL On an orange five I think I used it all the time except for fast descents. Then changed the bike.
Pedal masher by any chance?
Posted : 24/05/2012 10:34 am
same tune as mine - how heavy are you? Might be worthing swapping to a smaller air can or getting some of the Fox air volume reducers if you're a big unit. Mine's a 2011 BV which came with the XV can, swapped it for a standard can and made it much better - I'm 15 stone.
Mine's a single pivot but has a rocker link for comparison
Posted : 24/05/2012 10:41 am
I've forgotten what its like to ride a bike that has suspension that doesnt work for anything other than going down hill 😆
Posted : 24/05/2012 10:44 am
I run around 25% sag and only ever use pro-pedal in position 1 for fireroad climbs on my 5 and then only when I remember, even with that little amount of PP it feels a lot harsher on descents when I forget to turn it off, am heavier than you and the bike doesn't feel wallowy when climbing to me.
Posted : 24/05/2012 10:59 am
On an RP2 i run it on 20% sag with pro pedal off. I just turn it on for climbs and road. But then i've set the pro pedal to almost lock the shock.
Posted : 24/05/2012 1:02 pm
 GW
only in the text of the for sale ad 😉
Posted : 24/05/2012 1:28 pm
