When do eagle chain...
[Closed] When do eagle chain rings need replacement
[#11110710]
As title really. This is what I've got atm
https://photos.app.goo.gl/fGo7KFu3Mot5iPTZ9
Posted : 28/03/2020 6:58 pm
When they look like a normal chainring I guess😁
Posted : 28/03/2020 8:20 pm
There is quite a bit of wear on that Andy and I'd change it when it's next due a new chain or now if your chain isn't that old.personaly once worn I swap out for the steel versions which are £16 on tweeks genuine SRAM X sync boost as they last minimum twice as long but are heavy but it's an area I don't mind the extra late.
Although since switching to a wax based lube my STD original alloy one is holding up really well
Posted : 28/03/2020 9:02 pm
For reference it's the meat in between the narrow wide that's worn and wears and once the chain sits jn there baggy it also starts to prematurely wear your chain .
That's generally wear from muck and grit rather than actually crank revolutions so a steel one would be on my shopping list
Posted : 28/03/2020 9:05 pm
