Wheelbuilding Q - s...
[Closed] Wheelbuilding Q - spoke length
[#816588]
So am intending to build my first set of wheels - the DT calculator tells me I need 293mm both sides front and non drive rear, and 291 drive side rear.
Anyone know how critical this 2mm is? The reason I ask is that Ribble are doing big boxes of 292mm ones and I'm wondering if I can get away with using these for all the spokes.
Posted : 26/08/2009 3:35 pm
 sv
Have you measured the hub and rim yourself? Try the wheelpro calculator as it can throw up different figures. 1mm either side shouldnt make a difference.
Posted : 26/08/2009 3:37 pm
if the lenght is right then 1mm is fine
Posted : 26/08/2009 3:38 pm
I would put 292 all the way round on my own wheels.
I did the same with a bigger difference (3 mm ) it will be fine
Posted : 26/08/2009 3:40 pm
Many thanks, I'm ordering bike stuff now 😉
Posted : 26/08/2009 3:54 pm
Depends how particular you are with things like that.
I've built wheels with incorrect spoke lengths before, but find it easier to use the right length in terms of tension & dishing.
Posted : 26/08/2009 4:02 pm
