I need to purchase spokes and nipples for the following hub and rim set up. Hope pro II evo hubs and wtb st i23 rims.
Spec of rims are
HOLE: 32
COLOR: Black
INNER RIM WIDTH: 23mm
ERD: 603
RIM SIZE DESIGNATION: 23-622
Can someone point me in the direction of the exact spoke I need(not a spoke calculator!)
3 cross?
Hub Hope Pro 2, rear
Rim My rim
Spokes 32
Crosses 3
Spoke length left 292.5 mm
Spoke length right 292.5 mm
Hub Hope Pro 2 EVO, front
Rim My rim
Spokes 32
Crosses 3
Spoke length left 291.4 mm
Spoke length right 292.9 mm
What's the problem with spoke calculators? I find the wheelpro one better than the dt. It even has pre programmed data for common rims and hubs.
So would 295mm be ok
No you need front 291mm and 293mm and rear 293mm using 295mm is a no no
Many thanks now sorted cheers.
