Wheel truing advice
[Closed] Wheel truing advice
[#4231430]
So I got my wheel trued from the LBS. (I actually got my SO to drop it off pick it up as I work out of town and couldn't be there in person).
But the wheel isn't totally straight/true. I can still see a slight wobble when I spin it. The SO told me that the LBS said once a wheel goes out of shape it can't be straightened out fully, hence the noticeable wobble.
Is this correct? Should I be expecting more?
Posted : 06/08/2012 2:12 pm
Once a rim is bent you can't get a wheel perfectly straight, yes.
Is the tension off around the point in question?
Posted : 06/08/2012 2:14 pm
I've checked the tension, and everything seems ok in that regard.
Fair enough if the rim is bent. To be honest I'm quite surprised I managed to do this to them as I would have thought Flow rims would have stood up to a lot more. I'm not a rad rider, I just went for a stronger rim as I weigh 13st. But then that might be the problem!
Posted : 06/08/2012 2:21 pm
 sbob
No wheel will be "perfectly straight", but a half decent wheel builder should be able to true a wheel so it is difficult to see with the naked eye.
Buy a spoke key and have a crack yourself. It has saved me hundreds over the years (I'm keen but talentless, so have bent more than my fair share of wheels and can do a much better job than my LBS).
Posted : 06/08/2012 2:56 pm
Yes flows are tough rims, but it would also depend on the quality of the build in the first place. If was a poor build, it's always going to be difficult to correct it perfectly. A well built wheel should very rarely, if ever need truing up once it's built.
Posted : 06/08/2012 2:59 pm
