Wheel set recommend...
[Closed] Wheel set recommendations pls
[#6873640]
Hi,
I'm looking for a new wheelset that would be for my Cotic Soul. I want them to be light, strong and easily serviceable by me.
I live in the Peaks and ride my bike everywhere - but I am definitely more into crossing mountains and big days out than smashing it down the hardest stuff i can find. They'll also be used for some mountain marathons later in the year.
Any suggestions?
Posted : 19/02/2015 10:20 am
Budget? Front axle type? Shimano MT35 are £80 A PAIR at on-one. You can use an adapter if your front isn't 15mm.
Default (bling) answer will be Hope Pro2 Evo hubs with Stans rims. Near £250
Posted : 19/02/2015 10:28 am
Hi,
Thanks fo post.
Budget? Medium? I haven't loads but am happy to spend if I know they'll last. I do believe 'buy cheap buy twice'is true for a lot of stuff.
Size. 26" and standard qr.
Posted : 19/02/2015 10:33 am
Stans rims of your choice on Hope hubs.
Posted : 19/02/2015 10:37 am
WTB rims of your choice on Hope hubs
Posted : 19/02/2015 10:41 am
Your choice of Spank rims built up on Hope Evos.
Posted : 19/02/2015 10:43 am
rocketman - Member
Posted : 19/02/2015 10:46 am
Oops, my price was a bit out on Hope wheels, £300+ seems to be the going rate.
[url= http://www.rushcycles.co.uk/m50b7s482p4881/HOPE-Hope-Hoops-Pair-Pro-2-Evo-Hubs-on-Stans-Arch-Ex-rims/RS_GB/11857 ]http://www.rushcycles.co.uk/m50b7s482p4881/HOPE-Hope-Hoops-Pair-Pro-2-Evo-Hubs-on-Stans-Arch-Ex-rims/RS_GB/11857[/url]
However, on 26" there are loads of second hand bargains, and you could likely get a good set for half that.
Posted : 19/02/2015 10:54 am
Interesting rocket man. I run WTB rims now and they have been pretty good. It's the stupid non-servicebale-by-me hub (they were off a Trek Ex8 and need a 'key' to service and i cannot get it from anywhere. Even an LBS i went to gave up on them one time) that irritates me and hence the new wheel's.
Can I just put Hope hubs on them then?
Posted : 19/02/2015 10:57 am
Nope - I'm being a plonker. WTB were off another bike.
I have Bontranger TLR wheels. Can I just put Hope hubs on these to get around hub problem?
Posted : 19/02/2015 11:02 am
What is it that you need? Bonty hubs are usually DT Swiss internals, there is a tool you need to do the centre bearing, this one:
No other special tools though.
You won't get a massive improvement going to Stan's/Hope wheel, seems ludicrous to spend £300 on a largely comparable set of wheels to avoid fixing what you have.
Posted : 19/02/2015 11:13 am
edenvalleyboy
Mildly pointless re-lacing old rims on new hubs.
Double plonker -minds elsewhere. Bontranger Rythym Comp wheels. Can I put Hope Hubs on these? Cheers.
Njee20 - it's a tool to get a cap off to access bearings.
I see your point jimjam.
Posted : 19/02/2015 11:16 am
Hit with hammer 😕
Posted : 19/02/2015 11:19 am
Your bike rocketman?
Posted : 19/02/2015 11:20 am
Shall we all now post photos of broken rims with absolutely no context? I'll go first.
Posted : 19/02/2015 11:21 am
Njee - that's why nonTrek LBS gave it back. Didn't want to hit with hammer..maybe I should take my balls out of my handbag and just get on with the hammer..
Good info re comparable wheels. Totally right - should solve access problem. Otherwise waste of money.
Posted : 19/02/2015 11:22 am
It's usually just a case of sticking something through, and tapping the end cap out. Alternatively, you should be able to use an axle vice to pull them out. I'd be finding a new LBS if that flummoxed them. I can't recall Rhythm Comps specifically, but they're unlikely to be anything different.
Unless you go for a decent upgrade I'd say so - DT240s on Light Bicycle carbon would be very nice, and light, probably c1300g, but more like £600.
Posted : 19/02/2015 11:24 am
I never went back to them (LBS) based on that. Although apart from the wheel issue I do nearly everything else myself anyway..
Posted : 19/02/2015 11:40 am
Merlin have good deals on Fulcrum wheels if anyone's looking at those.
Posted : 19/02/2015 2:12 pm
Only just seen this but: I have a set of rhythm comps kicking about that I've taken apart before. IIRC the hubs are Formulas not DT. The back hub comes apart easily with cone spanners (20mm I think), bearings just tap out on the axle, although the freehub needs a daft imperial sized hex key (7/16"?). The front (mine is 9mm QR) has a notched lock ring that I think uses a tool a bit like a four-pronged freewheel tool, but I got it apart very easily with the first pin spanner I grabbed. If your LBS couldn't get them apart they need a bit of a kick up the bum, frankly, they're not trying very hard. 🙂
Give me a shout if you want any more info, my username at gmail dot com.
Posted : 28/02/2015 11:02 am
I have the WTB KOMi23 on Pro2Evo, still "new" to me, but seem fine. They now do an i25KOM for 2mm extra width. IIRC the KOMs are designed to [i]grip[/i] the tyre when dinged, if that helps!! I was hoping to desticker them, but the logos are non removeable - anyone have any ideas how to?
Posted : 28/02/2015 11:10 am
