Wheel rebuild - OK ...
[Closed] Wheel rebuild - OK to re-use spokes?
[#913743]
I ruined the rim from my rear wheel and have just got hold of a replcaement rim. Am i ok to use the spokes from the old wheel build or should I get new spokes? (both rims are dt 4.2ds)
Posted : 01/10/2009 3:03 pm
if they're quality spokes with no visible damage and yo trusted the original build, it should be okay.
Posted : 01/10/2009 3:04 pm
 cp
i've re-used spokes in the past and built perfectly fine wheels. It's more faff though.
And... you may find it a PITA to undo the nipples on the current wheel - if they're old/well used wheels, the nipples may be seized onto the spoke... solution - cut the spoke...
Posted : 01/10/2009 3:05 pm
I've re-used spokes many times with no problems. If the nipples have seized a bit of WD-40 or similar normally gets them moving.
If you are replacing a like for like rim, then the best way is to place the new rim next to the old one, wrap some tape around them at 3 or 4 points, then just transfer over the nipples and spokes one by one to the new rim - saves having to lace the spokes or anything. Easy 😀 just down to tensioning then.
Posted : 01/10/2009 3:12 pm
Cheers guys. Well I decided to reuse them. Wheel now laced but I think it may go to the LBS for tensioning and truing (plus for them to check my lacing 🙂 )
Posted : 01/10/2009 5:00 pm
have a go yourself. If you're not too sure, get the wheelpro book. Last set of wheels I had shop built, I checked with a park guage. Drive side tension varied from 17 to 23! When I did it myself, it ranged from 23-24
Guess which one will remain true the longest.
Posted : 01/10/2009 5:03 pm
Ditto - do it yourself - it's easy really - just use (for example) the Sheldon Brown guide
[url] http://www.sheldonbrown.com/wheelbuild.html [/url]
Posted : 01/10/2009 5:07 pm
