wheel bearings
[Closed] wheel bearings
[#3705118]
I've just noticed some play on my commuter rear wheel, the rim moves by a few mm side to side. Question is, is it fine to use in the meantime until, I get a chance to sort them out at the weekend or am I going to end up stranded facing a long walk?
Posted : 22/02/2012 8:45 pm
You won't get stranded you just need to sort asap longer it's left the worse it will get.
Posted : 22/02/2012 9:05 pm
Any idea how long its been like that?
The bearings/hub could be on its last legs already.
Posted : 22/02/2012 9:42 pm
No idea how long its been like it, under 100 miles since i gave it a clean and general check and i didnt notice it then. I'll break out the mtb for the rest of the week to be on the safe side.
Posted : 23/02/2012 1:21 am
Could be anything from loose cones to a snapped axle, to bearing cups migrating into the shell, to a loose freehub body. Come across all of them regularly, stick to the other bike just in case it's a bit serious.
Posted : 23/02/2012 8:49 am
So just taken the wheel apart and looks like the bearings:
Non-drive side:
Drive side:
Cleaned up side by side:
Would the worn down bearings have killed the hub? if not how do I tell what size new bearing to buy?
Wheel is a stock Pro-lite wheel that came on my Focus Mares
EDIT: A quick google suggests 1/4" bearings for wheels, so would something like this do:
http://www.ebay.co.uk/itm/Weldtite-loose-bike-ball-bearings-grease-various-sizes-/170647380834?pt=UK_sportsleisure_cycling_bikeparts_SR&var=&hash=item6d6fe7e9e0#ht_1142wt_1163
Posted : 25/02/2012 12:17 pm
