Whats yer veiw on M...
[Closed] Whats yer veiw on MTB verticle storage
[#962677]
My six month old MTB has started weeping oil from the Rock shox reba's under the Uturn knob the shop where I bought it from say this is down to the way its stowed (verticle back wheel grounded front wheel attached to the wall) thats bo**oxs I think as I have other bikes and have stored this way for years never any probs. 😕
Posted : 18/10/2009 9:01 pm
I doubt it. Fox forks are supposed to be stored upside down, and loads of shops have bikes stored that way.
Posted : 18/10/2009 9:08 pm
wouldn't the right way up have been more sensible - surely that's how most people keep their bikes ?
Posted : 18/10/2009 9:10 pm
My pace forks do the same but that's a well known 'feature' of them. All my other bikes are fine inc the ones with Rebas and Revelations so b*****ks
Yeah I suggested this as both my other bikes run Fox forx but the guy tells me that the fox use a cartridge oil and the rock shox use a open bath not being 100% on this I backed down, still think its Bo**ox though.
Posted : 18/10/2009 9:11 pm
 jonb
From my understanding there is only a small amount of oil in the forks (15ml?). It may be leaking from the valve, I get a small amountleak out when I remove my shock pump, are you sure it's not this and it's accumulated in the u-turn adjuster. It's supposed to be fairly easy to remove the u'turn so you could clean it up and see if it comes back.
Posted : 18/10/2009 9:15 pm
Also the usual side for rs forks to leak is on the damping side eg right, not the left u turn side.
My Rebas leaked oil when stored in the same position as yours. The seals were shagged.
Posted : 18/10/2009 9:17 pm
Deffo not the seals may be just a O ring underneathe the U turn cap yep should be easy to replace and there under warrenty so the shop can sort it, I think they run a small amount of oil in the compresion leg. I know the guy at the shop tell me to store it with both wheels on the groung.
Posted : 18/10/2009 9:23 pm
we have several bikes hanging up.
all the u-turn forks leaked when they were hanging from front wheel. the fixed travel ones didn't. hang the bike from rear wheel and it'll be fine.
Posted : 18/10/2009 9:28 pm
Taken from TF tuned F.A.Q [url= http://www.tftunedshox.com/faq/rock_pike_reba_revelation.aspx#link7 ]here[/url]
My U-Turn air fork leaks oil from under the U-Turn adjuster cap. What's this?
This only occurs when the bike is upside-down or on its side, when the lube from the lowers escapes through the top. During service, we fit a modified O-ring to reduce this significantly.
Posted : 18/10/2009 9:30 pm
Thanks for that same experience but why has it took six months to start happening and is it worth taking it back to the bike shop???
Posted : 18/10/2009 9:31 pm
NO idea why it's taken so long. it happened to ours within a week.
Posted : 18/10/2009 9:33 pm
Obviously rubbish forkks, should've bought fox 😉
Posted : 18/10/2009 9:42 pm
Fox next time for sure, will try storeing back wheel up
Cheers guys 🙂
Posted : 18/10/2009 9:54 pm
Mrs Flange (ha) has Reba's that have done the same thing. Piss oil out when hung the wrong way
Posted : 18/10/2009 10:36 pm
FWIW, I always clip-tie the brake levers too as it seems to prevent air moving up through the brake's servo system. Works a treat.
Posted : 18/10/2009 10:38 pm
Yep - store a rockshox equipped bike hanging by it's rear wheel to avoid the leaking.
Posted : 19/10/2009 7:52 am
I am with Ti 29, hang from the front wheel but have suffered bad brakes after being upside down. Fox forks seem fine with this.....
Posted : 19/10/2009 8:01 am
Ti29er - Member
You have servos in your brakes? Didn't realise they made ABS for bikes yet...
Posted : 19/10/2009 8:18 am
Move with the times 201, it's 2009 after all!
hydraulic brakes is what what I meant to say.
Clip-ties and gaffer tape fix most everything on a bike, but then I have Fox forks, Ikea Spoons and Gerber Knives.
Posted : 19/10/2009 10:09 am
