Whats the best 100 ...
[Closed] Whats the best 100 XC fork when it comes to lockout
[#3193089]
Im fed up with lockouts that dont ie - Reba SL & Team leaving and inch of travel and lockouts that dont unlock at the first sign of mud.
Must not need servicing every week !
Posted : 28/09/2011 5:32 pm
Magura forks with DLO become totally rigid apparently.
Posted : 28/09/2011 5:35 pm
DT Swiss go are totally rigid. The lever is pretty small and fragile mind.
Posted : 28/09/2011 5:37 pm
+1
Posted : 28/09/2011 5:38 pm
Mine certainly are - maybe one mm movement but nothing really.
Posted : 28/09/2011 6:09 pm
TBH I prefer the 'not totally locked out' feel of Rockshox but I very rarely if ever use it anyway...
Posted : 28/09/2011 6:45 pm
is the Magura much better than Rockshox where the lockout is at the top of the leg. Thats where my Rebas just gets clogged
Posted : 28/09/2011 7:13 pm
DT swiss with the fork top lever is good, I don't use the bar mounted lever. It locks where it is too so you can lock short or tall..
The twin shot system works very very well for climbing too.
Posted : 28/09/2011 10:59 pm
The floodgate should have enough adjustment that the forks have no movement when locked out. If they don't, then there isn't enough oil in the damper.
Posted : 28/09/2011 11:24 pm
I liked the "lock-down" rather than "lock-up" of my old Marzzochi Marathon SLs. Any other forks which lock out in the fully-compressed position? Windwave are a real PITA for spares and this has put me off another set of 'zochis.
Posted : 28/09/2011 11:39 pm
Yeh DT Swiss work well, totally rigid. Has fully open, rigid and a half way setting where the travel drops to about 60mm, pretty handy for steep climbs off road.
Came on a new bike, I like them a lot. Totally unscientific but I found them a lot easier to set-up right for my weight and riding style than Fox.
Posted : 29/09/2011 8:20 am
What about MoCo XX, no cables to get sticky.
Posted : 29/09/2011 9:48 am
Rockshox SID World cup, rock solid, very easy to set up. Shop around for last seasons for a bargin buy.
Posted : 29/09/2011 1:53 pm
Manitou R7 lookout to fully rigid as well and they are very light
Posted : 29/09/2011 1:59 pm
It's not a complete lockout but the xx rs moco is pretty much set and forget with the occasional 5 min bleed. You can firm up the mo-co lockout with a few extra mil's of oill in the damper side as long you get the rebound rod to move fully up and down. I would have to say that the fox lock out is the firmest I have used.
Posted : 29/09/2011 2:05 pm
I've raced on Fox F100X forks for years and found them pretty faultless (I don't do any servicing). You get a small amount of movement when they're locked out - maybe 1cm, but work really well.
Posted : 29/09/2011 2:14 pm
Fox 100.
Faultless.
Adjustable lockout too with my lever (it's got a barrel adjuster on it which adjusts it)
Posted : 29/09/2011 2:23 pm
Lock out on my 2008 Reba fork limits travel to a very small amount i reckon - perhaps 5mm.
Posted : 29/09/2011 2:47 pm
I'm very impressed with the lockdown on my Mav SC32s.
Posted : 29/09/2011 2:59 pm
The new Fox F100 / F120 forks with Terralogic are excellent. I have some of the F120s and when they only move when required, not cheap though.
Actual lockout i have used on Rockshox in the past and always found it to be pretty good - Reba Team and SID (I think race but not sure).
Posted : 29/09/2011 3:36 pm
