What's one of ...
[Closed] What's one of these called? (or small piece machining help)
[#9636432]
I'm guessing it might not be called a thing I can buy, but if anyone's got any ideas of what might a starting point for bodging, or even if you've got the skills and equipment to make one for me, that would be great.
Cheers!
pic and post below from mtbr
Update on shifter (posted also in Covert thread): My local expert mechanic (shoutout to Win at Win's Wheels, Westlake Village, CA) was able to do a Graves-like shifter hack using a KS Southpaw, with the hack at the shifter end, not the post end. [b]He took a small aluminum cylinder, ground one end to fit into the Southpaw, drilled a hole for a set screw,[/b] and voila! Love it...minimal throw, almost push-button-like.
Posted : 30/10/2017 5:44 pm
I maybe wrong..... but I think that is what is known as a handlebar. 😉
Posted : 30/10/2017 5:47 pm
What are we looking at?
Posted : 30/10/2017 5:50 pm
Pretty sure it's a handlebar grip. HTH 😀
Posted : 30/10/2017 6:00 pm
Might need to show us a before/after shot so we can be clear about the bit that's handmade
Posted : 30/10/2017 6:06 pm
I've always called them solderless nipples.
Posted : 30/10/2017 6:09 pm
Oh, wait, its a kitchen cabinet leg isn't it?
Posted : 30/10/2017 6:10 pm
The quoted thread on MTBR is about [url= http://forums.mtbr.com/ibis/converting-xtr-front-shifter-dropper-lever-graves-style-911179.html ]alternative dropper post levers[/url]
Posted : 30/10/2017 6:14 pm
From the description sounds like some form of clamp-on nipple to go on the end of the cable?
[url= https://www.sjscycles.co.uk/gear-spares/brompton-dr-gear-trigger-threaded-nipple/ ]Solderless nipple[/url]
solderless gear nipple. Thanks dovebiker! 😀
Not sure if that exact one will work, but there are plenty of others now I know what I'm looking for. Cheers again.
Posted : 30/10/2017 6:24 pm
^^Ahem!
Posted : 30/10/2017 7:37 pm
hack
OP reported for 2 violations of the verbal morality code.
Posted : 30/10/2017 7:43 pm
Onzadog, one thousand apologies. I saw a the first few replies, then scanned down to see if anyone had got the point. My eyes were drawn to the underlining in the link to the mtbr thread, then the subsequent underlining in dovebiker's post.
You were right all along, but you were just ahead of your time. I just didn't get it back then. Maybe I needed to get used to the idea, read it somewhere else with a line underneath to realise how much sense it made and how god-damn... [i]right[/i] it was. 😥
Sorry. And thanks.
Posted : 30/10/2017 9:37 pm
nedrapier - Member
[s]solderless gear[/s] nipple. Thanks dovebiker!
Pervert
Posted : 30/10/2017 9:41 pm
Rob, one hundred and twenty apologies for your hurt feelings.
given that it was a quotation, would you have preferred
was able to do a Graves-like shifter **** using a KS Southpaw, with the **** at the shifter end, not the post end
or
was able to do a Graves-like shifter hack [sic] using a KS Southpaw, with the hack [sic] at the shifter end, not the post end
Posted : 30/10/2017 9:42 pm
Couldn't find one the right size.
10cm brass rod from amazon, cut to size with hacksaw, put in a drill chuck and filed down to diameter. 1.25mm drill through lengthwise for the cable, 2.3mm drill through the end and tapped for M3 set screw grubnut.
Posted : 26/01/2018 6:51 pm
its called a knarp
Posted : 26/01/2018 9:05 pm
I've never seen one before. No-one has...
Posted : 26/01/2018 9:11 pm
Got one one in the spares tub that worked on a southpaw lever until i upgraded to a ReMote, if anyone needs one
Posted : 26/01/2018 9:47 pm
If that's a command post isn't there one at the other end? Just order from specialized spares.
Posted : 27/01/2018 11:39 am
Spesh lever, Thomson Post. S spares could have been good to know, but I've done it now!
Posted : 27/01/2018 11:56 am
Only just seen thread. Did wonder why you wouldn't spot it at the other end. 🙂
Posted : 27/01/2018 2:15 pm
