Whats my crank?
[Closed] Whats my crank?
[#10633918]
Direct Mount Road or Standard Mount Road?
Its a praxis alba on a 2019 Spesh Diverge. The two above need different spacers according to instructions!
Posted : 21/05/2019 7:41 pm
Worst game show idea ever.
Posted : 21/05/2019 7:59 pm
You could call it Crankety Crank.
Posted : 21/05/2019 8:01 pm
Whose Chainline Is It Anyway?
Posted : 21/05/2019 8:04 pm
I should get my crankity crank cheque book out and go to a shop!!
Posted : 21/05/2019 8:05 pm
In the hope of a proper answer it looks like this only dirtier!!
Posted : 21/05/2019 8:10 pm
From what I see on their website, the Direct Mount is SRAM standard, so you should see 3 Torx bolts around the spindle. If you don't (like in the image above), then it's a fixed spider.
Posted : 21/05/2019 8:20 pm
Thanks, so looks to be standard mount and needs a 2mm spacer.
Direct mount crank is about how the rings are mounted to the crank then? Like this:
Posted : 21/05/2019 8:29 pm
https://praxiscycles.com/product/alba-m30/
It can be but in this case it's how the spider is attached using the same interface so you could fit a direct mount ring or a different spider
Posted : 21/05/2019 8:56 pm
Direct mount then cheers, my googlefu is clearly weak!
Posted : 21/05/2019 9:46 pm
You are the weakest link. Goodbye.
Posted : 21/05/2019 10:02 pm
You are the weakest chain link. Goodbye
FTFY....
Posted : 21/05/2019 10:10 pm
