What Tyre Boot/Repa...
[Closed] What Tyre Boot/Repair Kit?
[#1691756]
I managed to put a 1.5cm slash in my Nobby Nics at Glentress last night. Have just gone tubeless so this isn't a great start - is it to be expected that you'll slash the sidewalls more on a tubeless set-up (it's never happened to me before in over 15 years of riding)?
Oh, and to the point of my post - what tyre repair systems would the STW massive recommend? So far, I've come across the Park ones (which look huge), the Pararacer ones and the Rema ones from CRC. What's the verdict?
Thanks
Posted : 10/06/2010 12:15 pm
Did a TCL course last week... they advise old toothpaste tubes, cut open....brilliant idea!...can't believe it's the first time I've seen it in 20yrs biking
Posted : 10/06/2010 12:39 pm
I managed to improvise with a bit of plastic last night, but was thinking about something more permanent/sticky...
Posted : 10/06/2010 12:43 pm
I think the toothpaste tube thing only works with a tube in there. As I recall the method is to sew with dental floss and then patch internally with rubber cement and a piece of old tube.
APF
Used a section of the tube that blew out when the tyre split last week.
Have successfully used the trimmed down plastic lid from a puncture repair kit, a sock, a bit of plastic bottle and an out of date bank card before now.
Each time, I swear I'll put something in the seatpack for the next blowout, but never do.
Posted : 10/06/2010 12:50 pm
for a standard tyre (ie: tubed) - look no further than duck tape!
No experience with UST types but I'd suggest inner tube to seal against air loss, and then duck tape to stop the flimsy rubber just blowing out of the gash.
Duck tape fixes everything, as long as you have enough of it.
Posted : 10/06/2010 12:54 pm
Get you back fixes - folded up crisp packets + bank notes, work with a tube
Posted : 10/06/2010 1:06 pm
+1 for duck tape.
I put a patch on the inside if the tyre and then used a piece of duck tape over the top. Still going strong after several weeks.
Matt
Posted : 10/06/2010 3:49 pm
