Boring I know but having recently, and in somewhat mysterious circumstances lost my trail pump. I would like some recommendations.
I like the look of the Crank Bros one with the double head and the pressure display.
Thanks
I've got an Innovations Second Wind MTB Pump - [url= http://www.bikeshop.uk.com/457/Innovations-Second-Wind-MTB-pump-and-co2.html?referrer=Froogle ]HERE -[/url] it's a normal pump or you can use CO2 cartridges for pumping up your tyres, I know which I use the most 🙂
It's small enough to slip into your camelbak & very easy to use, in fact I used mine today on a mates inner up on Dartmoor, 2 seconds job done.
Bit on the big side, but I use a Blackburn Mammoth. Pumps a lot of air per stroke(important in cold and wet conditions, nobody likes waiting for somebody pumping away like a 14yr old with a copy of Razzle), totally reliable, and if you do manage to lose an important part trailside whilst fixing somebody elses tube, you can buy spares kits cheaply.Smaller versions, and cheaper plastic ones are also available too.
I was looking for a pump a few weeks ago after snapping my Topeak which seized up mid ride.
Ended up buying a Lezyne, after spotting a topic on here with one reply that said
Lezyne.thread closed. 😀
Cheers MrNutt!! Well happy with it.
Yes oggles said lezyne are great, beautifully made and do the job.
Mountain morph
Trailk?
Is that a trail/track pump?
Believe me, don't. The last thing you want is a pump that **yikes!!** when you need it. Get a mountain morph - a pump not a toy.
Thanks for the advice. Looked at the Morph but ended up picking up a Topeak Mini G Master Blaster.
