Everything apart from fireroad? 😆
I just like going fast on dry slightly loose dirt with leaves scattered about in Autumn when its not too hot or cold, few little bumps and jumps but nothing that would upset anyone.
Air.
Nice post by James illustrated with pictures.
The third drop at Caddon Bankis also my nemesis.
Trail mincers with geared bikes
Oh dear.
That gap between the two rocks on Pennels Vennel. One day it is gonna be too deep for the pedals to clear the sides.
is jealous of the trails james rides, altho on that last one you do appear to have forgotten to get changed out of your pyjamas when you got up that morning 🙂
Recognise the scree, that's fun, scary as hell but fun 🙂 don't know any of the others but they look good.
Ruts, I hate ruts, either riding inside them or having one next to the trail I'm on, cannot for the life of me hold a line when there's ruts around. Not big on jumps either but as they only pop up on the occasional trail centre visit it's not often a problem. No need to mention wet roots, surely that's a universal thing....?
Seemingly innocuous off-camber turns. They hold a hex over me.
Anything involved roots, trees, tight gaps through trees or northshore
I should probably just ride above the tree line at all times....or maybe on the moon
Anything walking-speed slow & trialsy. Simply have no sense of balance below a certain speed
Otherwise OK 🙂
needing a poo usually knocks me off my flow a bit
Step down, corner type things. Like the one on Pie Run and at the bottom of the old Ewoks Village. Although interestingly, I've always managed to get around the one on Pie Run but never the other one at the end of Ewoks. THey dont hold any fear, I'm just a bit rubbish at them.
yunki - Member
I've discovered if you blast down a trail, the need mysteriously vanishes. Quite the opposite of what i expected. I think you can scare poo away (as long as the pace car is still out). Sometimes it can take hours to pluck up the courage to resurface.
+1 for damp, green chalk. There's a very long climb nearby that consists of lumps of flint embedded in chalk. In the summer, it's a test of fitness. In the winter, it's a test of bike control. If you're on a full suss with very spitty traction you quickly learn the art of speedy unclipping.
Oh and dropoffs. I hate them.
By the way, doesn't 'step down' technically means a jump where the landing is lower than the take-off, as opposed to just a step that can be rolled.
Grum, I'd say both count.
Either something rollable at slow speed, but 'steps down' if jumped, or simply a 'proper jump' with the landing lower.
In the same way a step up can be both....
James - I think those pictures were posted to invoke jealousy!!
DrP
I really don't like deep ruts in line with your wheel on steep descents. Keep thinking I'm going to catch the side and flip over the bars.
Steps, my back just does not like the repeated shocks 🙄 Legs tend to stop working for some reason 💡
Jumps of all and any kind for similar reasons. Just fever know if back will spasm 😡
I have a real mental block over really steep roll-ins but only if I stop before them. If I just ride them, no problem at all but every time I stop before it it's a coin toss as to whether I'll get the balls up to do them.
Jumps with a steepish takeoff ramp (the last big one of these kicked my rear wheel over my head...)
Jumps with gaps > about 2 feet
strangly if there isnt a take off 'ramp' and i can just launch flat drop to downramp or flat im happy with pretty much anything..... (that you would do on a mojo sl anyway!)
I don't like that corner on Pie Run either, it just looks guaranteed to catch my front wheel and land me on the deck.
I struggle with up hill steps as well, its probably just bad technique coupled with the fear that if I stall compeltely I will just fall over still clipped in!
+1 for wet roots and air over 0.5 secs in duration...
There's a couple of runs at Warncliffe that have lef hand switchback into right hand switchback on really steep soft ground that i just cannot carry any speed through. i always end up on the brakes too much and loose my front wheel. I just can't seem to get my weight in the right place, or i just need to man up and go for it, but trees hurt!!
Woodwork. Complete mental block.
