What tool for the b...
[Closed] What tool for the bottom bracket cup
[#11032230]
I'm servicing a child's bike with an old fashioned cup and cone bottom bracket. The fixed side has recessed 6 point star slots - like a giant torx bolt. I cannot find a tool to fit. I tried the Park Tool website but nothing obvious.
I tried using a flat steel bar which fitted nicely, but the ends snapped off. It's a steel cup in an aluminium frame so seized in.
Any idea what it's called or where to get a tool from?
Posted : 02/02/2020 10:40 am
Any chance of a photo?
Posted : 02/02/2020 10:52 am
Campagnolo?
https://www.sjscycles.co.uk/tools/campagnolo-utbb100-bottom-bracket-cartridge-tool/
Or a freewheel too?
Posted : 02/02/2020 10:54 am
probably cheaper in the long run to buy a new bike
Posted : 02/02/2020 10:57 am
Pipe wrench and a new bottom bracket
Posted : 02/02/2020 11:14 am
It's not the Campy one, I think their splines are in the outside of the cup rather than inside.
I cannot get a photo off my phone without seemingly sharing my Google account.
I don't need to replace it, I'm just curious what tool it is. As it's a child's bike it has an additional lock ring on the drive side to hold a plastic chain guard on.
*Edit, which seem to be a pain to get hold of it it ever did need replacing.
Posted : 02/02/2020 12:03 pm
Is it a lock ring? In which case a Park Tool
HCW-5 spanner would work. Fits into 3 of the 6 slots
Posted : 02/02/2020 1:50 pm
Not a lock ring, a recessed socket so need something with splines
Posted : 02/02/2020 3:13 pm
You should be able to post it via https://postimage.org/ or https://ctrlq.org/google/photos/ though I had issues with ctrlq last time I tried.
Posted : 02/02/2020 10:31 pm
BB BB pic
Ridgeback, the manufacturer got back to me. Apparently it's a random BB. They stopped using it because of the headache of not having a tool for it.
I'll fabricate something if I ever need to remove it completely.
Posted : 29/02/2020 11:41 am
If you remove the lockring it should relieve the tension and allow you to remove the fixed cup with molegrips or similar?
Posted : 29/02/2020 11:47 am
Any Star Wars fan could tell it's Imperial!
Posted : 29/02/2020 11:56 am
If its 6 or 8 little holes equally spaced on the bb cup around the axle, there is a tool for that, I would call it a peg spanner.
https://images.app.goo.gl/Yez7D3vV1MrtMSp98
Posted : 29/02/2020 3:19 pm
You can usually tap the left side off with a screwdriver and hammer. Once the axle is out put a big nut and bolt (around m14) through the axle hole and tighten it up with a big spanner. It should lock onto the fixed cup, keep tightening and this should loosen the cup as it has a left hand thread.
Posted : 29/02/2020 3:26 pm
