What tool do you us...
[Closed] What tool do you use to service ks seatpost ??
[#3277529]
Hi singletrackers have spent the last 1/2 hour trying to remove the service nut on my ks seatpost and just seem to be doing damage ! I am using thin nose pliers and grips what do you use ? thanks
Posted : 24/10/2011 6:55 pm
 Ewan
Take the nut off the bottom with a socket. Then use needle nose pliers as a pin spanner to get the bit with all the holes drilled in it off. Grip the shaft (ooo err) with one of those rubber strap wrench things.
Posted : 24/10/2011 8:59 pm
ice axe
Posted : 24/10/2011 9:03 pm
Posted : 24/10/2011 9:22 pm
Ewan's spot on. I seem to remember there was a certain amount of ignoring the instructions involved. Much easier with proper circlip pliars btw.
Posted : 24/10/2011 9:26 pm
Top tip which I saw somewhere and works a treat - if the bit with the holes in has seized and won't unscrew, put a screwdriver through the jaws of the needle-nose pliers for extra leverage.
Posted : 24/10/2011 10:29 pm
second the nearest bin
Posted : 24/10/2011 10:59 pm
 Ewan
Pah i've serviced mine quite a few times - it's fine. I used an adjustable spanner + pliers to get extra leverage the first time. Snapped my circlip pliers tho... (just don't do it up so tight when you put it together next)
Posted : 24/10/2011 11:03 pm
For everyone who wants to bin it- feel free to send your posts to me, mine is a fine bit of kit 😉
Posted : 25/10/2011 12:08 am
