What thick disc rot...
[Closed] What thick disc rotors for XT brakes?
[#7641290]
I hear that XT brakes work better with thick disc rotors. Any recommendations?
Posted : 11/02/2016 11:03 am
My new Formula 2-piece rotors seem quite thick in comparison to Hope and Hayes
Posted : 11/02/2016 11:10 am
You hear you say...
What about the xt rotors? Got hope floating on one bike and xt on the other, can't say rotor thickness feels like an issue unless your into the paper thin weight weenie ones...
Posted : 11/02/2016 11:13 am
 poah
I just use shimano icetech discs with slx and zee
Posted : 11/02/2016 11:32 am
I used XTs for a while with some Avid G3 rotors and the servo wave action makes them a bit bitey at the expense of modulation
They're better with RT 66/76s imo
Posted : 11/02/2016 11:43 am
Magura rotors are thicker (2mm vs a standard 1.8mm IIRC).
Posted : 11/02/2016 12:17 pm
So how does that work when your pads wear down?
I cant see how disc width is particularly relevant tbh.
Posted : 11/02/2016 12:21 pm
Apparently it does help solve a problem I posted about earlier
http://singletrackworld.com/forum/topic/whats-up-with-my-xt-brakes
Posted : 11/02/2016 12:38 pm
That was my issue and solution, however I since found I had a stuck piston.
They still bite better on a thicker disc.
Posted : 11/02/2016 1:48 pm
I got on well with the cheapy superstar rotors. I found they didn't warp nearly as badly as shimano or hopes.
Posted : 11/02/2016 2:10 pm
