what the hell have ...
[Closed] what the hell have i done!
[#3881822]
right folks i have managed to get my fox 36 to not hold any air.
i done this by having the shock pump still engaged as i bounced on the fork (stupid i know). every time i pump them up then remove the pump the ar just comes out the shrader valve
question is what have i most likely done? need the forks to be sorted asap.
any suggestions greatly appreciated.
Posted : 17/04/2012 7:18 pm
the valve core can be removed and checked / replaced
Posted : 17/04/2012 7:20 pm
so take core valve out and try and see if it hold air or not let any through?
Posted : 17/04/2012 7:54 pm
Take it out and see if its damaged - or just replace it.
Posted : 17/04/2012 7:56 pm
You've messed up the valve, or it's stuck down with some gunge. Take pump off, have a gentle dig about with a needle and try again.
Posted : 17/04/2012 7:57 pm
cheers guys.
I had a gentle dig around in the valve and it seems to be holding air now.
is it worth ordering a new valve or will it be ok now?
Posted : 17/04/2012 8:50 pm
Go to your local car thingy shop, the ones that sell all the stuff that people put on their cars. Askl for some tyre valves; you will probably be able to buy the tool and some spare valves.
This: http://www.fawkes-cycles.co.uk/1277945/products/Weldtite-Schrader-Key-Metal-Valve-Caps---Card-of-4.aspx?utm_source=Froogle&utm_medium=PriceComp&utm_term=Froogle&utm_content=None&utm_campaign=PriceComp1
Posted : 17/04/2012 9:00 pm
