What strimmer?
[Closed] What strimmer?
[#7846229]
My Jonsred GR50 strimmer has died a death. It needs a new silencer, the strimmer cord autofeed is broken, yet sometimes it feeds out a couple of feet of cord, threatening my shins. You can't get 5 minutes strimming done with out having to stop to adjust the cord. Basically I want something lighter and more modern.
However I want to be as capable, so the question is what petrol strimmer, 2hp/2kw, with a harness and cowhorn handle? My local shop only stocks strimmers up to 1.1kw. I think.
Obviously I could just go off and do some market research, but wondering if anyone has any first hand knowledge?
Posted : 23/05/2016 9:05 pm
I've been using a Hitatchi straight shaft for about 3 years. It gets used for hours at a time several times a week. Can run a disc too and it swaps over easily. Was about £100 cheaper than the stihl/husky equivalent powered machine. Got it from the big online place that's based in Gloucester mowers.co.uk or something. Can recommend.
The model I have is CG40EJ
Posted : 23/05/2016 9:13 pm
Not sure if their petrol strimmers are any better, but I have a Screwfix Titan 600W electric one and it's rubbish.
The autofeed has never worked since I got it. At first, it just spat a load of line out and whipped me across the shins. Ouch. Ever since, it doesn't autofeed at all. Tried taking the spool apart and re-winding the line - that didn't fix it. Tried replacing the spool - it worked for about 25 seconds, then stopped autofeeding again.
Shame, as it otherwise feels very well built for the money.
Posted : 23/05/2016 9:23 pm
Not a Ryobi - OK when it starts, but that is rare. Stihl is the way to go, 2nd usually fine
Posted : 23/05/2016 9:30 pm
I've asked the relevant members of the household and they reckon you're best bet is a mid range Ladyshave (i.e. Philips)
Posted : 23/05/2016 9:48 pm
I have one of these http://www.gardenmachinerydirect.co.uk/strimmers-and-brushcutters/honda-strimmers-and-brushcutters-umk425ue.html
East to start, efficient, not noisy, reliable and comfortable. Gets the job done using either the auto feed head or the 3 blade cutter for thicker brambles etc. Can also fit a rotary blade (not incl).
I'd happily recommend.
Posted : 23/05/2016 10:53 pm
