what stem for a 29e...
[Closed] what stem for a 29er
[#6917998]
Taking delivery of a Spesh enduro 29 and need to swap out the 70mm stem for something shorter.
I am 5th 11 and gone for a large frame, and thinking of a 50mm zero rise with a 10mm rise bar.
However I have seen the syntace flat force which has a 17 degree negative rise stem in 44mm.
I guess thecquestion is what stem sizes do you guys use? World of 29 is a bit new to me.
Posted : 09/03/2015 9:36 am
It will have a load to do with how the bike feels for you and your overall proportions, give it a few rides and work out what would feel better. Or the one that's on offer.
Posted : 09/03/2015 9:38 am
I've bought a cheap bar/stem (760mm/50mm) from On One to test on my new bike, before buying somthing "nice". Superstar were also selling control hardware off cheap using the voucher code "control25". So I'd suggest you experimenting with cheaper kit before laying out a load of cash.
Posted : 09/03/2015 10:17 am
I picked up an on-one 50mm stem for £20 on planet-x (and a tenner for some 760mm bars)
Posted : 09/03/2015 11:16 am
Funn 45mm stems on both my 29ers...
[url= http://www.chainreactioncycles.com/funn-funnduro-stem/rp-prod91491 ]http://www.chainreactioncycles.com/funn-funnduro-stem/rp-prod91491[/url]
Can't fault them at all.
Posted : 09/03/2015 11:44 am
Why so sure you need to swap it? Ride it for a bit first.
Was 50mm 0deg stem and 745 + 15 rise; but went to 70 0deg stem + 745 flat and found it much better
Posted : 09/03/2015 11:45 am
You going to be putting 650B+ wheels in it?
50mm stem no spacers and a flat bar BTW.
Posted : 09/03/2015 11:52 am
When I went to a 29er, I thought that the 70mm stem might be too short!
After a few rides I realised that actually it was about right for the handlebar width on the bike (which now feels a bit narrow).
Posted : 09/03/2015 12:09 pm
i use a 35mm, so you should too.
Posted : 09/03/2015 12:34 pm
Make sure it's a 29er specific stem
Posted : 09/03/2015 12:43 pm
will try 50mm..
Stu... it will have a 650b+ wheels, one of the reasons I got the bike... tried an sworks with the ohlins coil and fat tyres..... magic carpet ride came to mind
Posted : 09/03/2015 3:18 pm
Sounds interesting.
Bet it'll be great on your trails.
Posted : 09/03/2015 3:39 pm
Beware of the on-one stems, the faceplate corners cracked on mine.
Posted : 09/03/2015 3:56 pm
+1
Posted : 09/03/2015 4:09 pm
patriotpro - Member
Probably wasn't 29er specific...
Posted : 09/03/2015 4:26 pm
Nasher: I'm same height as you and recently had my Enduro 29er in large built with an 50mm Hope AM/FR stem and it's perfect for men
[URL= http://i48.photobucket.com/albums/f229/PSi3/D0F1B906-3BC6-4910-AA3B-FD544B5B5D43_zpstnl3yvl6.jp g" target="_blank">http://i48.photobucket.com/albums/f229/PSi3/D0F1B906-3BC6-4910-AA3B-FD544B5B5D43_zpstnl3yvl6.jp g"/> [/IMG][/URL]
Posted : 09/03/2015 8:00 pm
for me lol
Posted : 09/03/2015 8:33 pm
I'm selling a 55mm Easton Haven - all black....
It came off my 29er, so it's bound to fit 😉
Posted : 09/03/2015 8:35 pm
Using 50mm on my Spesh enduro 29er and its perfect
Posted : 09/03/2015 8:50 pm
DBL post
Posted : 09/03/2015 9:19 pm
70mm Thomson stem and s-works carbon flat bar on my stumpy 29'er.
Feels great, but I went through several setups before deciding on what I now ride. Be prepared to experiment
[url= http://www.pinkbike.com/photo/11738836/ ]http://www.pinkbike.com/photo/11738836/[/url]
Posted : 09/03/2015 9:24 pm
