What Steel hardtail...
[Closed] What Steel hardtail takes a 30.9 seatpost
 SOAP
[#4599886]
As above is the question?
Posted : 27/11/2012 5:16 pm
Cotic Soul
Posted : 27/11/2012 5:22 pm
Actually scratch that just realised it has a 31.6 so I'm talking garbage. I blame a lack of coffee
Posted : 27/11/2012 5:23 pm
Not sure if any steel HT is that big, but my S-Works Stumpy M5 alloy HT has a 30.9mm seatpost.
All my steel bikes use 27.2 or thinner.
PaulD
Posted : 27/11/2012 5:24 pm
27.2 on old soul and 31.6 on newer version.
I think the Ragleys are 30.9mm
Posted : 27/11/2012 5:25 pm
Original BFe.
Posted : 27/11/2012 5:30 pm
 SOAP
Edit 30.9 or bigger.
A new Soul would be nice .....
Posted : 27/11/2012 5:41 pm
Evil Sovereign takes a 31.6 post. Don't think there are too many steel HTs that do...
If you're basing the 30.9mm requirement around a current/future dropper seatpost, remember you can get 30.9mm-31.6mm seatpost shims so you can run a 30.9mm dropper in a 31.6mm frame if needed. USE, problem solvers, others?
Posted : 27/11/2012 6:35 pm
shims = superstar (*ducks the low flying bombers*) excellent proper ally not cheap USE plastic
Posted : 27/11/2012 6:41 pm
Santa Cruz sizes are 30.9mm not sure about steel.
Posted : 27/11/2012 6:42 pm
Pre 2012 Whyte 19s are 30.9mm, at least the 2010 and 2011 were. Nice frames too.
Posted : 27/11/2012 6:48 pm
"shims = superstar"
but they don't offer a 30.9-31.6mm shim?
I quite like the plastic USE ones. seem to slide against a post okay, better with a little grease/carbon paste. Treat them a bit cack handed ime and its then that they crack
Posted : 27/11/2012 6:53 pm
but they don't offer a 30.9 - 31.6
So they don't! Stupid Superstar 🙁
Posted : 27/11/2012 9:56 pm
