What size cone span...
[Closed] What size cone spanner(s) do I need to service a 6-Bolt XT hub?
[#801644]
...and where can I get them from!
CRC would be brilliant, as I could still (possibly) get them by tomorrow...
Thanks guys!
Posted : 20/08/2009 3:50 pm
 Jay
15 & 17mm if i remember correctly.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=10200 ]X-Tools Spanners @ £3 each[/url]
Posted : 20/08/2009 4:04 pm
15mm and 17mm (Park SCW-15 and SCW-17). Helps to have a pair of each (plus an extra hand 🙂 ) when tightening up.
Posted : 20/08/2009 4:06 pm
Thanks guys!
I also did a bit of ferreting myself and found this:
http://www.bikemagic.com/news/article/mps/uan/3318
Posted : 20/08/2009 4:09 pm
some old imperial ones and a file for mine.
10000 times easier if you can put the axel in a vice, either that of mil grips on one end and hold them between your knees.
Posted : 20/08/2009 4:10 pm
I needed an 18mm for the rear - it's a couple of years old though - M756 i think. Only need it for one side though as you can brace the lock nut with something else and you only have to undo one side to slide axle out.
I noticed my cones were loose today when changing a tyre - I have finger tightened them which is totally wrong, but will they be safe to ride on for a fast 2hr blast?
Posted : 20/08/2009 4:26 pm
Yeah, I've ridden long distances like that - they're not going to go anywhere if the QR's done up properly! Obviously you'll notice a bit of slop at the rim. It does seem a couple of years back that the nuts weren't tight enough from new, and often came loose on new hubs as a result.
Posted : 20/08/2009 5:09 pm
