What should I be lo...
[Closed] What should I be looking for when buying a 2nd hand full-susser?
[#3869863]
An Ibis Mojo as it happens with DT Swiss forks
Posted : 14/04/2012 12:23 pm
cracks
Posted : 14/04/2012 1:10 pm
hi there,
I would do the basic checks - seatpost moves up / down ok - check for play in headset and that the gears work ok and if you can get a chain checker tool to see how worn the chain is... spin wheels and check disc rotors for any rub / check pads and tyres
Then waggle wheels to see if theres any play in bearings / any play may be the wheel or the shock bush / linkages - test for that by taking wheels out and then move the linkages etc - you will be able to feel if the pivots are tight / worn..
check the shocks work and no obvious damage or movement - inquire into service history - re forks ask when last serviced / any receipts etc - maybe budget for a service or replace the odd part... see if the shock and fork accept air ok...
do visual checks on the frame for any damage / cracks - pay attention to headtube area - see if any bad chainsuck - check dearaileur hanger and the condition of the jockey wheels = gives a good idea of wear - make sure pedals arent wrecked... go with your gut feeling re sale
cheers
paul
Posted : 14/04/2012 1:14 pm
wheels
Posted : 14/04/2012 1:16 pm
2nd hand FS with DT Swiss forks?
Best keep an eye out for new forks and new rear shock service in the very near future..
Posted : 14/04/2012 1:37 pm
 DT78
Do you know the rider/ how well they treat their kit/ miles they do? Definitely budget for shock and fork services if not done in the last 12-18 months. Check chain wear, could need new drive. Check all bearings, shock mounts. Look for cracks.
Posted : 14/04/2012 1:43 pm
 deus
Don't believe the bearings and shock in very good condition claims on ebay, mostly it's lies IME....
Posted : 14/04/2012 2:18 pm
I always budget for bearings tbh- though I've bought I think 5 used full sussers and only one needed new bearings immediately, it's good to anticipate it.
Posted : 14/04/2012 2:27 pm
