what shock position...
[Closed] what shock position?
[#4183616]
building a kona stinky 24 and seem to be stuck at the first hurdle!
in what hole do I mount the shock and what is the difference?
there seems to be no difference in length (i did a rough measurement).
Anyone got any idea?
Thanks again!
Simone
Posted : 21/07/2012 11:28 pm
 GW
one position is slightly more progressive than the other
won't make a whole load of difference TBH
Posted : 21/07/2012 11:37 pm
 JoeG
You know that it is a kids bike with 24" wheels, I hope.
I think that yours is a 2007, based on [url= http://www.konabikeworld.com/bikes/2k7/STINKY24/index.html ]this page[/url] from the Kona website. It shows the shock bolt in the front position, and I don't see any mention of variable geometry or travel, so I don't know why there are two mounting holes.
The 2008 frame looks the same, other than color [url= http://www.konabikeworld.com/08_stinky24_w.htm ]here[/url] [url= http://www.konabikeworld.com/KonaCatalog08.pdf ]and here.[/url]
I looked at some of [url= http://www.konaworld.com/tech.cfm ]Kona's Tech Stuff[/url] but didn't see anything.
The 2010 and newer Stinky 2-4 appears to be a different frame design, with only one mounting hole.
I'd probably contact the appropriate person from their [url= http://www.konaworld.com/contact.cfm ]contacts page.[/url]
Posted : 22/07/2012 12:27 am
 GW
Joe - not sure how you missed it but I've already answered the question correctly.
Posted : 22/07/2012 12:47 am
 JoeG
GW - Member
GW - Sorry; I didn't know that it was a test! Congratulations on your correct answer; would you please show me where the OP and I should have looked in order to find this answer that you provided? I'm asking since I didn't find anything about tuning the travel to be more or less progressive on Kona's website.
And most manufacturers make a point of boasting about the tuning options of their bike, even if it is a small one like 10mm of travel. And this is a kid's bike (though a pretty nice one) which makes me wonder whether the riders would be knowledgeable enough to understand whether they needed more or less progressive suspension, and then communicate that...
Posted : 22/07/2012 3:31 am
...mmmm so still not sure what i should use, may just stick with where it was originally!
This bike will be used in the alps by my 9 year old for some lift assisted riding. Bit over the top, but it was a bargain!
Posted : 22/07/2012 9:27 am
Rear hole = more progressive so will ramp up and prevent bottom out on big hucks and gnarrr
Front hole = more linear
For a 9 year old that probably weighs not very much, the front hole would be fine, I'd have thought.
Posted : 22/07/2012 10:01 am
Cheers rickos, my 9 year old is a wuss, so front hole it is!
Posted : 22/07/2012 10:06 am
