Ok it's a bad question but I really don't know the answer.....
I'm just putting a big order into CRC and want to get a chain ready for replacement for the summer.
There are loads to choose from ?!? I have a standard 9 speed and will be replacing the cassette with a Shimano M770.
Cheers for the help and abuse :0)
Gary
None, get a KMC instead.
go for a SRAM or KMC - so much easier to fit and swap with a powerlink
+1 for KMC. My Shimano chain goes brown at the slightest hint of moisture in the air, unlike my KMC which still sparkles like new.
I fitted a KMC last night. Is it just me, or is the 'MissingLink' a pain in the ass to remove without tools (unlike the SRAM powerlink).
Use a KMC with a Sram powerlink.
I snapped two shimano chains, maybe 10 years ago right enough, but since then I've bunged £15-ish SRAM chains on.
Look at this way, last time I bought a complete bike the first thing I did was remove the shimano chain. Even if you don't think they are fragile, the link joining method is a faff.
wippermann conex
+1 Wippermann, they last forever seemingly. Then KMC, Shimano and SRAM in descending order. The only good chain-related things SRAM make are their old 8-speed chains and power-links IMO.
To redress the balance, I always use Shimano chains on my bikes as I find them stronger than Sram if joined correctly. I use the Dura Ace/XTR quality though and clean and re lube as described, I've never broken one and cover a lot of miles and stress them a fair bit racing.
Thanks everyone for your help, sorted for Sram now :0)
+1 for duraace. I've had three SRAM ones snap. Maybe a bad lot but never had a problem with shimano.
Will probably try kmc next time for a change
