What RS fork seal/s...
[Closed] What RS fork seal/service kit should I get?
 DrP
[#4557278]
I'm confused.
I've a set of revelations bought off here, and I think they're 2010 models, though googling them brings up lots of different variations.
Essentially, they have:
-air u-turn
-150-120mm travel
-blackbox damping
-motion control
-external compression and rebound
-20mm maxle...
I've serviced them a few times, but am looking to replace the o-rings and oil foam.
Any ideas what kit I should get, and where's best for it?
A chap on eBay sells a 32mm o-ring kit, but not sure if that's what I'm after, given the u-turn and BB damping...
Ta muchly!
DrP
Posted : 14/11/2012 4:26 pm
 DrP
Ok - so by rearranging the google search phrase, i get [url= http://www.bikeradar.com/gear/category/components/forks-suspension/product/review-rockshox-revelation-team-air-u-turn-10-35363 ]RS Rev tear air u-turn 2010 forks....[/url]
The last few questions still stand though!
DrP
Posted : 14/11/2012 4:29 pm
If they aren't leaking, don't bother buying seals. Fresh oil will see them all lovely again.
I've serviced more RS forks than I can remember and only ever replaced one leaky o ring.
But if you need some odd bits, email me, I've got some stuff lying around in little boxes in the garage. 🙂
Posted : 14/11/2012 4:47 pm
 DrP
I think the oil seals could do with replacing (well, the oil foam ring). Any of those pete??
DrP
Posted : 14/11/2012 4:50 pm
I've got some used ones hanging around somewhere I think. 🙂
They should be OK. I can look tonight if you like?
Posted : 14/11/2012 4:53 pm
 DrP
That would be stirling...!
Cheers bud 🙂
DrP
Posted : 14/11/2012 4:57 pm
The top seal above the foam ring is a special Rockshox part. It's only a dust seal to stop crap getting in. If there's another seal BELOW the foam ring then they are a standard hydraulic ram seal and about £1 or so each. I used to have a link to a place that sold them.... Deleted now I think. The internal O rings are, again, all off the shelf things. I measure them up and just find something similar. They do t even have to be the same size, as long as they're close-ish they'll be fine. But like I said, unless you have a leak (air or oil) there's little point in changing them for the sake of it. I just wait until they go off for a proper bushing service as they do the lot then
Posted : 14/11/2012 4:59 pm
 DrP
Cheers,
I'm happy servicing them, but could do with changing the foam ring TBH, as i haven't done that yet.
Any recommendations for where sells them new?
P
Posted : 14/11/2012 5:17 pm
Loco is the place to go to if you need to buy the foam rings seperately
Posted : 14/11/2012 5:23 pm
Yeah, he's the daddy.
Dr P, I've got a couple of used ones. They look OK actually. I'll send you a pic 🙂
Posted : 14/11/2012 6:17 pm
