What Rims should I ...
[Closed] What Rims should I buy?
[#1419236]
Hello I have a problem with a common condition known as 'Heavy Bike' everybody knows to start with their wheels so that is what I am doing. 🙂
At current I have Hope Pro II on Mavic EX823 UST, these are near 680grams or so (HEAVY)
I have been looking at other Mavics and there are some XC rims at around 400 grams.
The bike is a 17" Orange P7 and I will be taking it to wales for some Hardcore-Hardtail Insane-Terrain.
Does anyone know of a nice light rim that can handle abuse, or at least something lighter than the 823. I don't need downhill rims.
Taa very much
Posted : 17/03/2010 9:19 am
May I be the first to recommend the Stans Flow rim. It's 475g but tough enough for light DH use and can be run tubeless for further weight saving. For hardore riding you'll need the stans rim strip, not just the yellow rim tape, for tubeless. Maxxis tyres work really well as with these rims tubeless as do the new Specialized 2Bliss tyres.
Posted : 17/03/2010 9:22 am
Mavic 719s would be my choice for a light but toughish rim
Posted : 17/03/2010 9:30 am
Mr Poddy's idea seconded.
Posted : 17/03/2010 9:50 am
I can agree with both replies.
I have used the 719s for 2 years and they are still tight and true.
And currently using the Flow rims for 6 months and are very good.
Just depends how wide you want the rim.
External rim width of: 24mm ish for the 719s, and 28mm for the flows.
I think it also depends on what you want the rim to do. The Flow has 100g more material in it so it's going to be a heck of a lot tougher than the 719 as well as wider and thus able to run a 2.35" tyre.
I don't think they are remotely comparable but I know that that's not what people intended here. I couldn't possibly get away with a 719 as I'm just too heavy and aggressive (read clumsy!), but a very skilled rider could probably run them for aggressive trail riding.
Posted : 17/03/2010 9:56 am
 StuF
+1 for the 719s, I run those on my Cove HJ - no problems even for my 90kgs
Posted : 17/03/2010 9:59 am
Thanks!
The Stans rims look lovely but my main concern with them is that I could get a pair of 719's for the price of one Flow rim,
this will take some thinking on my behalf. Can I justify? hmm yes no yes no :S
Posted : 17/03/2010 10:04 am
Huh? The Flows are 460g. Even 717s are only 395g.
The Stan's Arch would be both lighter and tougher than the 719 IMO, the Flow is altogether tougher.
If you're getting Hope hubs, why not buy Hope Hoops on Flows? The extra cost of the rim doesn't matter then.
Posted : 17/03/2010 10:07 am
 nuke
[i]The Flow has 100g more material in it so it's going to be a heck of a lot tougher than the 719 as well as wider and thus able to run a 2.35" tyre. [/i]
No, based on the respective websites, the Flow is 10g heavier...470g for Flow, 460g for 719.
Both good rims and I have got both but given only the marginal extra weight for the extra width, I'd take the Flows.
Posted : 17/03/2010 10:08 am
Not quite sure where the 'double the price of a 719' is coming from either?
719 Disks are £40, have a search around, you can find Flows for £50.
Posted : 17/03/2010 10:10 am
Sorry - my mistake. I was thinking the 717 (which are lighter although not by 100g as Njee points out).
Posted : 17/03/2010 10:11 am
If you want a new wheel rather than just new rims then Hope Hoops are amazing value for money and would allow you to get the Flow/Arch rims pretty much for the same money as the Mavic equivalent.
Posted : 17/03/2010 10:12 am
 tron
EN521s weigh in at 540 grammes and still let you run decent sized tyres. The "XC" rims all seem to top out at 2.3" tyres, which is a bit of a gip on a hardtail, where you need high volume tyres to give some cushioning.
Posted : 17/03/2010 10:13 am
721s light enough for all day riding but tough enough for dh riding.
One rim to rule them all. Well apart from XC.
Posted : 17/03/2010 10:40 am
+1 for the 521's. I have them on Hope hubs. I am pretty clumsy and have not managed to knock them out of true after 9 months of big rocky descents. Good compromise between weight, strength and price. As above, 719's not meant to be used above 2.3 tyres although I bet a lot do
Posted : 17/03/2010 10:50 am
I was basing the price of a Stans rim from rutland which was the only mention here
http://www.singletrackworld.com/forum/topic/stans-flow-rims-cheapest-place-to-get-them
Stans being £81 on rutland - http://www.rutlandcycling.com/c/366/Rims-MTB.html?Page=2
and...
Mavic being £40.99 on CRC - http://www.chainreactioncycles.com/Models.aspx?ModelID=16641
Wherever you are getting them for £50 I don't know . . . But I'll have two! 😀
Posted : 17/03/2010 5:32 pm
