What rear tyre are ...
[Closed] What rear tyre are you running on your DW-Link Flux / 5-Spot?
[#4001911]
Hi Chaps,
What rear tyre are you using on your Flux or 5-Spot? It's not just a noddy, what tyre thread... the clearance is bonkers low - and interested to know what low profile, good mud clearing tyres people are using...
Cheers chaps
Ricks
Posted : 23/05/2012 10:39 am
High roller 2.35 - no problems with clearance.
Posted : 23/05/2012 10:58 am
Poop the bed!
2.25 RocketRon on the rear and there's about 2mm of clearance.
I seem to remember that the Exception series Maxxis tyres had a low profile, so might actually be a good option.
Posted : 23/05/2012 11:20 am
Rubber queens might be a tad tall in 2.2
Posted : 23/05/2012 11:21 am
I've had zero problems with that exact tyre. Maybe the 2011s had improved clearance?
Posted : 23/05/2012 11:26 am
mostly dependent on which rims you are running I would assume?
Posted : 23/05/2012 11:49 am
Hmmm... the ERD + the rim depth + the tyre profile...
Wont the tyre bead be mounted at the same point regardless though.... the bead doesn't have much stretch does it?
Posted : 23/05/2012 11:56 am
I've found 2.25 rocket rons to be quite 'high' as well (can't give you any more engineering fact than that), find I can't get away with them on the front using SID's (might be down to a relatively flexy front wheel also).
Posted : 23/05/2012 12:01 pm
Panaracer Fire XC Pro 2.1 wire bead on either DT Swiss 420's or Mavic 317's. Seems to give enough clearance for me.
Also tried with Mountain King 2.1's as well, still ok.
Posted : 23/05/2012 12:46 pm
2.25 Rocket Ron, no issues.
Posted : 23/05/2012 1:08 pm
Dickie - with your RR, how much clearance do you have at DW-link pivot - i.e. the base of the chain stays.
It's not the side of the tyre that gives small clearance, it's the top - i.e. height, not width.
Posted : 23/05/2012 1:14 pm
I'll have a check tonight.
Posted : 23/05/2012 1:22 pm
2.25 snakeskin Racing Ralph on a Stans arch. Plenty of space.
Posted : 23/05/2012 8:24 pm
 AD
1.9 High Roller - huge amounts of clearance...
Posted : 23/05/2012 8:39 pm
I have run a 2.5 HR on the back of my 5 spot and currently have a 2.25 Ardent on. Loads of clearance
Posted : 23/05/2012 9:17 pm
got a 2.3 high roller on at the mo have run a 2.4 mountain king and a 2.35 bonty XR4 and there massive!
bonty`s
Posted : 23/05/2012 9:27 pm
