Internals of rock shinx mainly, what do You use
I think its a bit of broom handle, wood not plastic
Off cut of 15mm? plastic pipe if I need to push something through a stanchion
Small toilet brush in the parts washer for cleaning the lowers
Broom handle with a hole drilled through the end to push the cloth through.
Anything that doesn't fall apart/snap too easily. I've used garden cane before now!
20mm pvc conduit pipe cos you can tuck a rag inside, about £1.50 for a 2 metre length from toolstation or screwfix.
Toilet brush.
I use an offcut of hosepipe with kitchen paper rotated into the end .
Mods, can the title of this thread be changed for comedy value?
Yeah, 20mm plastic conduit. I drill a few holes towards the end, then feed weave a rag around it.
I use a long piece of wooden dowel about 10mm diameter. Cut a slit into bottom of it and a piece of folded up paper towel slotted in, sprayed with ISOpropyl
Same as superfli! Glad I'm not the only one.
....although I have once left a paper towel in a fork lower and had 'fun' getting it out.
