what pikes
[Closed] what pikes
[#2559128]
looking for some second hand pikes what is the best model to go for? would be grateful of some info
Posted : 12/03/2011 10:54 pm
454 dual air [U -turn] unless you know a specfic spring weight will be Ok for you. i am a light weight whippet so needed air
Very adjustable as well with positive and negative air + lockout and floodgate adjustment - so they work if you forget to switch lock out off for a descent.
Cant recommend enough though I have not tried other Pikes
Posted : 12/03/2011 10:59 pm
454 Dual air. Maybe uturn if you need it.
Good forks, but the damper leaks a bit & the air chamber can need a rebuild if they start to feel funny.
Posted : 12/03/2011 11:30 pm
Do you want air or coil?
Air - lighter, more adjustable.
Coil - more durable, plusher.
(Others may not agree).
Posted : 12/03/2011 11:47 pm
Coil 454's if you can find them.
Posted : 12/03/2011 11:49 pm
454 I've had both coil and air and Push'd coil all of them are pretty good, the new Revelations are slightly better .
Posted : 13/03/2011 12:03 am
