What part required ...
[Closed] What part required - rear brake mount?
[#7659980]
I'm just doing up the GF's bike and need a mount to get the rear brake fitted.
Pic here:
Would something like this do:
http://www.chainreactioncycles.com/avid-disc-brake-adaptor-hardware/rp-prod108155
which is a 20mm ISO adaptor, or, just fit spacers to existing?
20mm looks about right to me - the one fitted is 0mm.
Any clues?
Thanks
Alan.
Posted : 20/02/2016 3:04 pm
And the disc diameter is ??
Posted : 20/02/2016 3:14 pm
180mm
Posted : 20/02/2016 3:17 pm
Assuming you are replacing something already fitted then the change in disc diameter will tell you what adaptor - eg going from a 160mm to 180mm disc requires +20mm as you identified.
I would go with a new single adaptor myself rather than piutting spacers omn the existing one.
Posted : 20/02/2016 3:18 pm
No, it hasnt had discs on before, so I'm making it up from odd bits I've bought/got in the shed.
I'll measure the gap with a little more accuracy, and hopefully it'll be 20mm and an easy to get part.
thanks
Posted : 20/02/2016 3:22 pm
What is the 'base' diameter of the caliper mount on that frame? Could well be 140mm, in which case you would need a +40mm adapter for a 180mm disc.
(20mm gap on the mounts = 40mm on diameter)
Posted : 20/02/2016 3:24 pm
You need this Shimano adapter (£5.99): http://www.chainreactioncycles.com/shimano-mount-adaptor-rear-post-to-is/rp-prod13749. Choose the 180mm option.
Posted : 20/02/2016 3:29 pm
+40mm universal IS to PM adapter or a rear specific IS to PM 180mm
"base" front disc is 160 and rear 140 hence is using the smallest IS to PM adapter hence +40mm universal front or rear adapter
Posted : 20/02/2016 3:43 pm
5 English pounds gets you the right adapter from superstar. You need type 4:
http://www.superstarcomponents.com/en/disc-brake-adaptor.htm
Posted : 20/02/2016 4:37 pm
Thanks all, I took the pic to the LBS, along with the 0MM mount, and he gave me a Shimano mount, here:
http://www.bike-discount.de/en/buy/shimano-adaptor-sm-ma-r180p-s-rear-180mm-is-2000-26793
Which is exactly the right part, and amazed me that he had one in, I'd expected to have to order it. £10, so not over-priced too.
Thanks all.
Posted : 20/02/2016 5:07 pm
Same as the one on the CRC site recommended above. Good to hear you got it sorted quickly.
Posted : 20/02/2016 11:15 pm
