what pads for the a...
[Closed] what pads for the alps?
[#609100]
off to cham in a couple of weeks so getting my bike prepared
am i right in thinking organic pads are better as they generate less heat or is it the other way round?
thanks
Posted : 05/06/2009 7:22 pm
I always use sintered. Put a new set in and 5 mins from leaving the chair lift they are nice and bedded in. They don't really get much choice. I've found that I can easily use one set for the week, even if it's wet.
Posted : 05/06/2009 7:28 pm
Sintered handle heat better but transfer more heat into the calipers. So you have less chance of pad fade but more of boiling the fluid.
I'd go with sintered
Posted : 05/06/2009 7:38 pm
What brakes do you have?
Posted : 05/06/2009 7:39 pm
Hope m4's on a heckler
Posted : 05/06/2009 7:43 pm
Ah i was going to suggest Ashima sos for the best of both worlds but they don't make them for hopes.
Posted : 05/06/2009 7:46 pm
There is a pad producer called Ashima and they do a duel compound pad for most brakes. Its called the s.o.s pad (sinterd, organic, sinterd)
I would use this as it gives you instant bite but with much less heat transfer.
www.ashima.com.tw/products_01_04.html
Posted : 05/06/2009 7:48 pm
I run sintered on M4s on the tandem - only in real extreme provocation have they overheated and they last well
thanks
typically i have 4 sets of unused hope organic pads in my bike box and no sintered!
thats life i suppose - merlin herei come
Posted : 05/06/2009 7:53 pm
