What oil pike ???
[Closed] What oil pike ???
 jeb
[#512763]
Hellooo
I am about to order some stendec oil from CRC, should
i get the 5w and the 15w
Posted : 29/04/2009 7:51 pm
Well, technically, yes. 5wt for the damping and 15wt to lubricate the internals of the other leg.
BUT
I've run RS forks on 5wt throughout with no problems for a couple of years, and it'll probably be cheaper to buy a litre from a motorcyle shop. It's usually about £7 a litre
Posted : 29/04/2009 7:55 pm
I haven't bothered with the 15wt for years. However, instead of using 5wt for the semi-bath like peter, I use some fully sythetic engine oil, since I've got 5 litres of the stuff for the car anyway.
Posted : 29/04/2009 8:12 pm
My pikes ( I dunno if different models are different) use 5 wt oil in a sealed cartridge damper and 15 w as lube in the bottom of both fork legs. as the 15 w is only used as lube I don't see that it really matters what oil it is so long as it won/t attack the seals and is thin enough to reach where it should and thick enough to lube.
I happened to have the right oils when I did mine - but would have been quite happy using 5 w fork oil throughout or engine oil for the lube oil
Posted : 29/04/2009 8:43 pm
