what mtb shoes do y...
[Closed] what mtb shoes do you use.
 ton
[#1796224]
boring i know, but i used to wear spesh bg shoes, but the latest models with the ratchet are shyte (imho).
they just do not get on with my feet.
offroad i have been using 5/10s and flats,but on loger rides i need some spd's.
i have wide feet, i also need something suitable to walk up steep stuff in,so stiff [s]ballet[/s] cycling shoes are not a option.
help.
Posted : 13/07/2010 8:05 pm
Several mates use Shimano MT90's, or whatever the current model is, all year round - for rides where walking is a must I'll wear them. Have had mine for several years and will be replacing them without hesitation once the current pair die.
Posted : 13/07/2010 8:12 pm
 ton
mate, had the original ones, which were ace, but the current ones are too narrow.
Posted : 13/07/2010 8:13 pm
[url= http://www.wiggle.co.uk/p/cycle/7/dhb_M1_MTB_Shoes/5360033176/ ]These[/url]
Nicely made, but absolutely rubbish in the wet; the breathing holes let water pour in.
Posted : 13/07/2010 8:14 pm
Sidi Dominators
Posted : 13/07/2010 8:20 pm
M21's and MO86's.
Posted : 13/07/2010 8:23 pm
Polaris something or other. I think Polaris make some of the most under-rated great value kit out there.
Posted : 13/07/2010 8:27 pm
Lake MX165s when it's dry, Lake MX140s when it's not. Best fitting shoes I've worn (I have a comparatively broad forefoot if that helps), very grippy rubber with big lugs for grip, comfy enough to walk for short periods in and plenty stiff for pedaling. They seem to be quite high volume so I have to put an extra half insole under the front to take up some toe room.
Posted : 13/07/2010 8:30 pm
Either spesh or shimano do a custom fitting option. Worth a try?
Posted : 13/07/2010 8:34 pm
Spesh BG in summer and shimano mw for winter
Posted : 13/07/2010 8:37 pm
Shimano shoes are narrow.
May be worth looking at Bontrager- they're the widest riding shoes I've tried and seem good. Can't comment on performance as they were so wide I can't ride in them with my skinny feet.
Posted : 13/07/2010 8:38 pm
Shimano DX's are comfy, fit my wide feet ok.
Posted : 13/07/2010 8:45 pm
Ton, can you not get a wide fit Shimano shoe? I can't normally get into Shimano shoes. but a 44 wide is PERFECT for my size 9s.
Posted : 13/07/2010 8:58 pm
shimano DX are wide - 44s fit my size 9.5s perfectly
Posted : 13/07/2010 8:59 pm
vans for cheap from ebay.
Posted : 13/07/2010 9:08 pm
Spesh ratchet ones circa 08, get on with them fine. Not to sure about the white colour scheme and stick on sole on the latest version.
Posted : 13/07/2010 9:11 pm
have Shimano AM50's as I kept cutting my ankles on stuff but they are giving my right foot little pinky grief, as I think they are too thin.
Swear by Spesh shoes, so because of above I have gone back to them and the possibility of cut ankles
Will just wear the Shimano boots on known rocky stuff for protection
Posted : 13/07/2010 9:17 pm
Etnies Locut or Vans Mid Skool.
Posted : 13/07/2010 9:23 pm
I'm on my third pair of DX's. So good in fact I've never tried anything else.
Posted : 13/07/2010 9:24 pm
What about something like [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=24882 ]this[/url]? Wider because they are skate shoe styled but still SPD compatible...not sure how hard wearing they are mind.
Posted : 13/07/2010 9:25 pm
Shimano DX (like the ones above)and Shimano M181 off road, Gearne on road. Waffle soles on the bmx :-).
Posted : 13/07/2010 9:27 pm
Spesh Tahoe very comfy for a wider foot,
I have wide feet and use Specialized BG Sport
Posted : 13/07/2010 9:58 pm
shimmy DX's and Nike YVr's here
Posted : 13/07/2010 10:02 pm
 ton
just bought some black dx's.
gonna give then a try.
got some 661's but to make then engage with a platform spd pedal, i will have to take a knife to them, which i do not want to do.
Posted : 13/07/2010 10:05 pm
Ton i use Lake's in the wide fitting. Had the Spesh BG Taho's before which i liked but the Lakes are a better option and nice and flexi with the Vibracom sole 😛
Posted : 13/07/2010 10:09 pm
Spesh BG Comp shoes - too stiff for you though 🙂
Posted : 13/07/2010 10:10 pm
The sole on my specialized saw pit shoes has just cracked. They were so comfy. Bought some shimano but they are a bit too small, even though I bought a size bigger than usual. God knows what I'll get next.
Posted : 13/07/2010 10:12 pm
Sidi Eagle 6 SRS Carbons and some Spesh BG Pro's. The fit of the Spesh shoes take some beating but the soles very worn now so don't use them that often. I got the Sidi's very cheap and they are very nice shoes and you can replace the soles which is ace.
Posted : 13/07/2010 10:33 pm
 LoCo
Shimano DX.
Worn with seal skins socks in the winter are good enough for 4 hour rides in monsoon condition too.
Posted : 13/07/2010 10:58 pm
 Haze
661 Filters & Sidi Dominators 🙂
Posted : 13/07/2010 11:04 pm
 LMT
Yep ive got a pair of those stormtrooper white style shimano dx, most comfortable biking shoe ive ever had, will get the new black ones for the winter.
Before that i had a pair of speshi tahoo, they lasted about 2 years, fit well and when waterproofed held off most of the water.
Posted : 13/07/2010 11:10 pm
Lake MX165's. I do a lot of hike a bike (often carry for a couple of hours to get to the good tracks). Good amount of rubber on the sole for grip. They wear really well (I have had 4 years out of the current pair) and they are comfy both on and off the bike. I did have a pair of Pearl Izumi Alp-x shoes recently, but wrecked them in under 6 months...
Posted : 14/07/2010 12:44 am
Vans.
Posted : 14/07/2010 1:24 am
sidi dragons. Ace.
Posted : 14/07/2010 7:03 am
 Sam
I like Sidis, but given your requirements they may not suit, though they do a 'mega' extra-wide fitting. Carnac are very wide and roomy shoes IME.
Posted : 14/07/2010 8:09 am
whats a 'loger' rides please ? riding logs ? great 😉
if you have wide feet...ie like Frodo, then go for five-tens.. 😳
spesh shoes are always narrow....
Posted : 14/07/2010 8:18 am
[SpokesCycles - Member
May be worth looking at Bontrager- they're the widest riding shoes I've tried and seem good. Can't comment on performance as they were so wide I can't ride in them with my skinny feet]
plus 1, Bontrager (which used to be branded Nike) are the only shoes that I can find to fit my obviously weird wide and high feet...
Posted : 14/07/2010 11:10 am
I have very wide feet too. Shimano M086 are very good I've found - flexy enough to walk in but stiff enough that they don't feel flexy on the bike.
And they come in a brill gold/bronze colour 🙂
http://www.sjscycles.co.uk/product.asp?pf_id=18312&src=froogle
Posted : 14/07/2010 11:13 am
specialized bg comp here. good shoes, if not the lightest, but fairly narrow cut.
those bronze/white shimanoes look ace!!
Posted : 14/07/2010 12:03 pm
5:10's for flats, Sidi Dragon 2's for SPD, Spesh Defrosters for winter/lots of mud
Posted : 14/07/2010 12:04 pm
Most comfortable MTB shoes I've ever worn
http://www.awcycles.co.uk/brands/Northwave/Lizzard_PRO_MTB_Shoe,_2010/11741/index.aspx
I've never bought the same twice in shoes, but I'll buy these again when they die. Nice wide fitting too.
Posted : 14/07/2010 12:21 pm
Spesh BH Sport(?) shoes with Sealskinz socks. They're bottom of the range, but simple (all velcro), solid and cheapish.
Posted : 14/07/2010 12:26 pm
Nike Poo Bahs. State of the art shit.
Posted : 14/07/2010 12:27 pm
Shimano DX. best shoes ever
Posted : 14/07/2010 12:30 pm
