What mount do I nee...
[Closed] What mount do I need...
[#5382026]
New frame, rear brake calliper mount to run a 160mm rotor?
Never built a frame up before so not sure...?
Link appreciated
Posted : 31/07/2013 5:20 pm
Possibly none. Is it Post Mount or IS and is your brake Post Mount or IS?
Posted : 31/07/2013 5:21 pm
Ahem ?
How do I find out these details....
Posted : 31/07/2013 5:31 pm
On your frame you will have one of these (these are forks but you get the idea):
Post mount:
IS mount:
Nearly all brakes are post mount, but often come with an IS adapter fitted. 160 is 'standard' on most frames so if it is post you won't need an adapter and if if is IS then you will need a 160 IS to Post rear adapter
Posted : 31/07/2013 5:53 pm
Right it's post mount then at the rear, so I don't need an adapter? Just bolt the calliper straight on?
Posted : 31/07/2013 8:33 pm
Should be fine for 160mm rotor
Posted : 01/08/2013 9:57 am
popps - Member
Usually, yes - occasionally, the post mount will be for a larger rotor, mine is 180mm.
Posted : 01/08/2013 10:22 am
