Think I need a new one, as we were testing mine the other day, could hardly get 50psi on a road tyre.
http://www.bikeradar.com/gear/category/tools/cycling-tools/mini-pump/product/flow-drive-m-pump-33716
This looks fairly good - anyone used it? Any other recomendations?
A fellow guest in Morzine had one of [url= http://www.allterraincycles.co.uk/product/107918.html ]these[/url]. Really light, really well made (part of Snap-on corp), and reasonably priced. Worked far better than any other pump that people had. Can't recommend it high enough - it got a lot of use around the resort. 😆
This one is so quick and plenty of folk have borrowed it when out on the trails:
http://www.chainreactioncycles.com/Models.aspx?ModelID=2909
Does look quite nice.
second ^^^ tis a good pump
Lezyne too, a real step up on other pumps (albeit not for cheapskates).
Bit of a faff working out which to buy - Alloy Drive for MTB, Pressure drive if you swing both ways and Road Drive for skinny tyres. Even the carbon versions probably work out as a bigger bang for the buck than EPO 🙂
not a crank bros power pump alloy. If i were buying now I'd want that topeak one C_G mentions. definitely. might even try to sell my crank bros one for it.
Anything BUT a crankbros.
The Topeak Morph linked above is good. But the plastic foot stand is a bit brittle. Lezyne do an all metal mini track pump too for about the same price and is a bit more durable. Albeit that the pressure guage is tempremental.
