After over 20 years of service my mini pump (can't remember make) has finally died (very kindly at the top of the Marin trail!).
What should I replace it with. I ride both MTB and Road and need it to work with both presto and Schrader valves.
Less than £25 would be ideal.
Lezyne Alloy Drive if you want something neat and shiny that fits in a back pocket. Topeak Morph if you want ease of pumping - not the easiest to change between Presta and Schrader, but such a good design otherwise.
http://www.chainreactioncycles.com/Models.aspx?ModelID=45879
Like a Topeak Morph, only more durable. TBH once you've had a decent sized pump with a hose and footrest it's almost impossible to go back to a silly little pocket pump.
