What length square ...
[Closed] What length square taper bottom bracket
[#1055674]
Basically need to know what length square taper bottom bracket for standard inbred gona fit some old middleburns. cheers
Posted : 19/11/2009 7:23 pm
I have a Royce 109mm in my Ti 456 and Middleburn`s. Its a neat fit mind.
Posted : 19/11/2009 7:45 pm
 nuke
Running 118mm on my Inbred 853...any narrower and the chainrings would foul the stays from what I can see. Given the 50mm chainline, pretty sure 118mm is what Brant recommended.
Posted : 19/11/2009 7:48 pm
113 is the length I would suggest.
[url= http://www.middleburn.co.uk/tech_bblength.php ]Middleburn tech [/url]
Posted : 19/11/2009 7:54 pm
 nuke
Hopster - Have you got an Inbred with a ST BB?
Posted : 19/11/2009 7:55 pm
 PJay
If it's a current model Inbred with extrawide bridgeless stays then, as Nuke says, you'll need a 50mm chainline to get anything like enough chainring clearance (IMO it's a real minus point for the On-One frames). The correct axle length for a 50mm chainline depends on the cranks. On my 853 Inbred with an XT Octalink crankset I need a 118mm axle but it can differ between cranksets (I'm fairly sure that there was an old LX chainset that needed a 121mm axle to give a 47.5mm chainline). Someone was asking about Deore square tapers a while and I think that they needed a shorter axle than their Octalink counterparts to give the same chainline. From the link that hopster has put up it looks like a 113mm axle will give a 50mm chainline but it might be worth checking with Middleburn in case your older model cranks were different.
Posted : 19/11/2009 8:49 pm
