Yes, it is a Bodge It and Co version. It lights 3 Cree Q5s very well for ages, but I would like to know what new smaller LEDS I could run from it and how, in series like the Crees?
They will be stuck to a Al heatsink with a switch, which isolates the buckpuck from the battery. Wire is 4 core. Very receptive to any I could buy from a STW member. just need LED's and Optics.
the new smaller LEDs run off the same voltage as the ones you already have.
3.7v per LED + at least 1v over for the buckpuck, a 14.8v battery pack will limit you to only 3 LEDS no matter which you choose.
You will be able to get more light because the new CREE XPG LEDs are more efficient.
i run a trout XPE6 with one of those battery packs
Ok, what 3 leds and optics do I order from [url= http://www.cutter.com.au/products.php?cat=Cree+XPG ]here?[/url]
Trout uses a maxflex or something to boost the voltage - I think.
I am rather limited to the buckpuck.
XPEMR8SER (3 XPG's in series mounted on a board) with Carclo 20mm Triple Optics for XPE? £22 plus postage and taxes?
