what is the right r...
[Closed] what is the right rear shock for a 2006 enduro
[#605863]
ive got the chance to purchase a 2006 enduro frame without the shock for a good price.
i was just wondering what the shock options are for this frame .
from the cheapest just to get it up and running through tothe most expensive .
cant afford it with the dhx thats fitted at mo but cant really let the frame go .
cheers
steve
Posted : 04/06/2009 8:58 pm
if you want cheap, i've got an old 5th element which is off an 05 enduro. it's not amazing, but it does hold pressure. on the 06 they changed it to a DHX air which is meant to be better
i have a DHX coil on mine, which is really nice and plush although adds a bit of weight. if you do find one the right length (222mm/57mm) it also needs to have the boost valve thing removed or it won't fit in the frame, so they are quite hard to come by. i got lucky with a 2nd hand one that had hardly been used
Posted : 04/06/2009 9:15 pm
to buy a DHX air or coil, i think its about £300 new, plus a bit to custom remove the boost valve
Posted : 04/06/2009 9:17 pm
"plus a bit to custom remove the boost valve "
no need to remove it, just use the low BB shuttle and replace the metal valve cap with a flat plastic one.
I have an 06 enduro with a bust rear chainstay so you can have my DHX 5 coil if you want.
it's a 2.75" stroke with a 425lb steel spring on it. Used for about a year on a medium 06 s-works enduro with no problems.
You'll need to use the low BB shuttle with it or get a reducer spacer fitted to take it down to 2.5" stroke if you want to use the high BB shuttle.
drop me a mail to a_paiceathotmaildotcom if you want more info
Posted : 04/06/2009 9:37 pm
how much for the 5th element pete????
Posted : 04/06/2009 10:10 pm
