What is the differe...
[Closed] What is the difference between cheap and expensive fork oil?
[#5312405]
Ok so I am going to try and service my 888's. I have done domains before but I used some juice lubes fork oil. for the 888's I'm going to need a litre bottle, which in juice lubes will cost me around £20.
http://www.bicyclechain.co.uk/productdetails.asp?productid=19465&gclid=CNGRv4iyn7gCFaTItAodoCwAUA
Or I could just use some motorcycle oil which would be a lot cheaper for a litre http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_221375_langId_-1_categoryId_165507
Should I cheap out or Is it the same stuff?
Posted : 08/07/2013 8:41 am
Bout £30/litre?
My coat please.
Posted : 08/07/2013 8:44 am
Mountainbike specific packaging.
How old are the 888's I was using mid spec m'cycle stuff in my old ones, couldn't really tell any difference
They are 2012 Marzocchi 888 rcv
Posted : 08/07/2013 8:46 am
Motorcycle oil.
Motul, silkolene designed to cope with just as much abuse as MTB fork oil.
Probably made in the same factory and using posh packaging
Posted : 08/07/2013 8:54 am
Absolutely no difference. Furthermore, the oil weights on the bottles bear little resemblance to the actual weights. There's a comparison chart somewhere on t'internet which shows the actual weights for most of the fork oil brands. Silkolene's a good one, BTW.
You want maxima from dirtbikebitz the racing one. 11 a litre. Very close sae to the stock zocchi
Posted : 08/07/2013 8:55 am
