What is the cause o...
[Closed] What is the cause of the wear of the third generation of the sand making machine
[#9305221]
The third generation of sand making machine is a new type of sand making machine to break through the traditional sand making machine bottleneck of technology innovation, strong performance of the device has multiple characteristics and incomparable, with high efficiency and energy saving, stable and long service life with countless users to bring great benefits, along with our country construction efforts continue to increase, aggregate demand increases, stone production equipment has better prospects for development. Now, with the continuous improvement of China's science and technology, the third generation Artificial Sand Making Machine in the sand making machine manufacturers continue to develop and optimize the market has become a hot topic in the relevant market, which has been widely used in many fields.
However, for the third generation of sand making machine, as a mechanical device, although it has a strong performance, but due to friction and long time production of hard material of wear-resistant parts caused by, if the user has also do not care about the case may lead to decreased production of equipment, a series of problems such as life expectancy. The third generation of sand making machine core components is the main function of hammer, hammer used in the case of high-speed rotation of the material crushing work is essential in the third generation of sand making machine parts, is also the most vulnerable to wear parts wear, once the parts subject to wear, will cause a decline in production of the product quality. Efficiency and other factors, therefore, the wear resistance of the hammer is the common concern of the third generation of sand making machine manufacturers and users of the problem, as the sand making machine professional manufacturer, Zhengzhou future machinery tried, found that high manganese steel, high chromium and tungsten titanium alloy and other metal as the third generation of sand making machine manufacturing raw materials more hammer can lengthen the service life of the hammer, and also improve the third generation of sand making machine, the whole production level. So what are the causes of the wear of the third generation of sand making machine? The future mechanical research found the following three points:
First, the hardness and fragmentation of the broken material. The material and material hammer hardness is proportional to the physical properties of the materials used for different hammers of different materials, which helps to make the hammer to extend the noodles. Therefore, in the use of VSI5X Sand Making Machine equipment, according to the characteristics of the material to choose the right material hammer.
Second, hammer production process. The manufacture of any product is similar to the principle of our cooking, grasp the best treatment program, make the best food to eat. In the same way, the quality of the equipment is the most reliable. The material structure of the hammer has an effect on the mechanical properties of the hammer after heat treatment. Reasonable casting process and heat treatment process is an effective way to solve the problem that the hammer is easy to break.
Third, the third generation of sand machine rotor power and speed. Different sand making equipment has different working conditions and relevant technical parameters. These technical parameters also affect the service life of the hammer.
Here, the future of Zhengzhou machinery is necessary to remind users: to the timing of the VSI Sand Making Machine maintenance, which can protect the equipment more long-term to provide you with effective work. For the third generation of the hammer machine need to regularly check, so as not to damage in the case of the replacement of your income.
Posted : 03/05/2017 7:19 am
I'd put that on eBay..
Posted : 03/05/2017 7:21 am
Sounds interesting.
Conveniently though, there's a quarry along the road from me where sand is dug out of the ground, negating the need to make it with a machine.
Posted : 03/05/2017 7:25 am
excellent. Can I get it bar mounted so it can fire a carpet of sand out in front of me and make a fat bike finally of some use?
Wow, 3G sand. Ossums.
Posted : 03/05/2017 7:26 am
