What is the average...
[Closed] What is the average cost for new spoke plus fitting at a LBS?
[#4637575]
more or less than £15??
Thank you!
Posted : 10/12/2012 10:22 am
£10
Posted : 10/12/2012 10:23 am
£15 + cost of spoke
Posted : 10/12/2012 10:25 am
Recently had 3 replaced and wheel re-trued for £13 including the cost of the spokes.
Posted : 10/12/2012 10:30 am
 LoCo
£15 plus the spoke/spokes if the wheel has the tyre and tube is off, as the wheel could be a proper taco and take a good while to true.
Posted : 10/12/2012 10:34 am
£10
Where in the country are the '£15 + spokes' shops?
Posted : 10/12/2012 10:37 am
Been charged between £7 & £17 for spoke replacement at my lbs. Weirdly, the more expensive one had everything stripped off the wheel, whereas the cheap one I just went in with the wheel fully built.
Both prices include spoke & new rim tape.
Posted : 10/12/2012 10:40 am
The amount of work involved could vary a lot depending on how well built the wheel was to start with. Also, as above, if the tyre/tube/cassette need removing that adds to the faff significantly.
Posted : 10/12/2012 10:44 am
 LoCo
It could be a really quick job or take ages so a sensible shop would charge about £15 😉
Posted : 10/12/2012 10:49 am
£10-15 depending on whether it's front or back, how taco-ed, etc. I'll always also advise that if more than 2 spokes are broken then the rest are likely to go soon so a rebuild would be a good idea.
Posted : 10/12/2012 11:35 am
 mboy
Cost of the spoke (usually £1) plus cost of labour @ £35 per hour.
If you come in with a stripped down wheel and it takes 5 minutes to do its gonna be a lot cheaper than if I've got to remove the tyre, rimstrip and anything else...
Makes sense really!
Posted : 10/12/2012 12:24 pm
I regard £4 as standard. Thats including a quid for the spoke. Of course other work costs more.
FoD prices 😆
Posted : 10/12/2012 12:38 pm
£10. No need to remove tyre usually.
Posted : 10/12/2012 12:43 pm
Jeez. 50pea per DT Swiss DB black spokes + post and I did three in my wheel, total cost £4 including 2 spares and posting.
Do it yourself, it isn't rocket science.
Posted : 10/12/2012 12:51 pm
Very easy to DIY for a single spoke. Hardest bit is fishing the nipple out of the hollow section rim, as I always seem to drop mine in there....
Posted : 10/12/2012 12:53 pm
