What helmets for a ...
[Closed] What helmets for a narrow, long bonce ?
[#7551791]
I've struggled over the years, helmets are always tight "front to back" and way loose "side to side" - padding helps of course, but what helmets suit such a bonce - any advice ?
Posted : 02/01/2016 9:47 pm
Troy Lee A1 I reckon.
Posted : 02/01/2016 9:48 pm
I have the same problem. No luck for me so far.
Posted : 02/01/2016 9:50 pm
Based on the head moulds used, I'd suggest MET. Most other brands use a Northern European head mould (Giro, Bell, etc), while MET use a Southern European shape, which tends to be a little longer and narrower.
Posted : 02/01/2016 9:53 pm
I had similar problems, the 2 best fitting lids I've ended up with are the Scott Stego and the Bell Super. The Scott is probably a slightly better fit but the Bell comes down lower so feels slightly more protective.
Best bet is to get out and try as many as you can.
Posted : 02/01/2016 9:59 pm
Giro for my long head.
Posted : 02/01/2016 10:14 pm
Giro for me too. Had a couple, best fit for my canoe noggin. I started the same post a couple of years back. was same conclusion then too 🙂
Posted : 03/01/2016 12:36 am
Giro here too. Same problem combined with v large head - so Giro might simply be bigger but the tightness on others for me is always front to back.
Posted : 03/01/2016 1:05 am
Giro and Cateye work for me. The Cateye can be tight if I haven't had a haircut recently.
Didn't get on with Met Helmets as they didn't pass the sitting in the shop test,I had a head in a vice feeling.
Posted : 03/01/2016 11:06 am
Fox flux is the only lid I've found that fits my long head. Tight and uncomfortable but I can get it on my head at least....
Edit: slight thread hijack, what fullfaces do you guys have? Havent found one that fits yet
Posted : 03/01/2016 11:12 am
Couldn't find a full face to get round this problem. The giro was nowhere near. Ended up with an old specialised but it's still too short.
Posted : 03/01/2016 11:44 am
bell super and urge down a matic for me. used to have fox flux. fits aren't grear but the best i can get!
Posted : 03/01/2016 11:46 am
My tsg superlight fits me like a glove.
My met is also a good fit.
Bell super is way too big side to side
Troy lee a1 fits but is depressingly expensive
My old giro is good but I've not tried a modern one.
Bluegrass goldeneye also a good fit.
(Finally got a decent bike shop in brighton)
Posted : 03/01/2016 12:18 pm
