What Grease and Gre...
[Closed] What Grease and Grease gun for a 5 spots bushings?
[#4963716]
Picking my new to me 5 spot up tomorrow off of funkrodent and was thinking of giving the bushes a lube up !
Can anyone recommend a good grease to use and also where can i get a gun to fit the zerks fittings?
cheers
Steve
Posted : 15/03/2013 1:49 pm
manitou prep m is the one Turner used to sell and recommend to use.
this grease gun is great as it screws right on the prep m tube
http://www.jejamescycles.co.uk/dualco-grease-gun-top-id20199.html
Posted : 15/03/2013 1:59 pm
http://www.silverfish-uk.com/ProductDetail/9858/9861/Super-Lube-Grease
Turner are now listing SuperLube
Posted : 15/03/2013 2:28 pm
is tere much difference between the two and why have they changed the preffered grease ?
Posted : 15/03/2013 2:31 pm
Not sure what the newer 5 spots are like for greasing but my HL one needs a long needle also to get to the grease point behind the shock. The turner ones were curved but you can you the long needle one, just unbolt the shock one end to get to it.
Got a longer needle from billys
[url= http://www.billys.co.uk/english/group.php?prod=2dul-mininoz ]here[/url]
Posted : 15/03/2013 2:35 pm
http://forums.mtbr.com/turner/lube-super-lube-manitou-prep-m-other-687952.html
seems super lube is the one to get
Posted : 15/03/2013 2:37 pm
I think prep m is harder to find now?
I think I read on here that Turner say you can use vaseline as well...?
Posted : 15/03/2013 2:38 pm
straight from Mr Turner himself
We switched to the super lube instead of MPrep for 2 reasons. First, the Motorex made MPrep went up again in cost. Second, the MPrep was a sticky stringy mess and I was tired of not being able to wash my bike without using degreaser to clean the frame around the pivots. The performance is great, almost as light as the original MPrep which was a Maxima product and that helps it purge.
DT
Posted : 15/03/2013 2:40 pm
vaseline does the trick very nicely indeed.
for the grease gun, get this - http://www.evanscycles.com/products/dualco/grease-gun-ec005503
assuming you have a DW Link 5-spot, you may then need to find a long needle nose end to attach which you can then bend with a pipe bender to reach the all the zerks.
with a HL frame, you can reach all with the standard nose end, by simply releasing the top shock mount
Posted : 15/03/2013 5:18 pm
An old Pace grease gun with long nozzle & Pace RC7 grease has worked for me for 8 years
Posted : 15/03/2013 10:10 pm
