What front Forks to...
[Closed] What front Forks to put on gt I drive 2.0 2001
[#3494840]
Got an gt I drive 2.0 off the classifieds. Just curious which forks n travel I'm best to go with, I plan to use the bike as a play bike to mainly use at a local freeride park?
Posted : 26/12/2011 9:01 pm
you can only put a fork with the original amount of travel on, i think its 85mm
Posted : 26/12/2011 9:07 pm
 mboy
Those old I drives came fitted with Rockshox Psylo forks, which were 125mm of travel. So anything up to or around that length is going to be fine...
Posted : 26/12/2011 9:09 pm
just checked meant to run at 100mm
Posted : 26/12/2011 9:11 pm
You certainly don't have to put a fork on with the same travel as the original .
Posted : 26/12/2011 9:27 pm
 mboy
You didn't read what I wrote then? Cos they all came fitted with 125mm travel Psylo's from the factory!
Some of the lower models came with 100mm Judy's, but the 2 and the 1 had 125mm Psylo's for sure...
Posted : 26/12/2011 9:31 pm
Most of the 01s had 100mm forks, but there was at least one race model- might've been the Team, maybe it was the Race- that came with an 80mm fork.
Posted : 26/12/2011 9:45 pm
I started mtb on a rigid Raleigh M-trax ,courtesy of some compo from an rta my first 'proper' mtb was a GT STS-XCR1000 . it came with Rockshox sid xc forks that were 100m travel I swapped them for some Psylo race forks and ran them at 125mm with no ill effects.
Posted : 26/12/2011 9:58 pm
 mboy
The 99 and 2000 model years came with 100mm forks, for 01 the top models came with 125mm forks.
The "Race" model you refer to was a shorter travel frame designed for XC racing, and did come with an 80mm fork yes I match the 80mm rear end travel, not the 115mm of travel of the longer travel versions...
That cleared it up much? 😉
Posted : 26/12/2011 11:00 pm
If its that green and black i-drive 2 I had one of those and it came with 100-125mm u-turn (internal adjust) Psylos.
Heavy but very very good xc frame.
Posted : 27/12/2011 1:45 am
lol its 1 in the morning and were arguing over how much travel a bike from 10 years ago had.. i love this forum
Posted : 27/12/2011 1:50 am
 bol
So, in answer to the OP's question regarding which forks to fit, I'd personally suggest a set of rockshox reba 120s from the classifieds when some turn up.
Posted : 27/12/2011 8:12 am
Cheers - managed to get hold of some psylos in the classifieds
Posted : 27/12/2011 9:40 am
