Thinking of running a 130mm/140mm Fox on an S Works Enduro to save weight over the e150. Anyone else run that and how do you get on with it.
I had Revelations on mine and it was fine, even in the alps !
Now got Pikes and its super.
140mm seems fine to me. I know it was a frame designed for 160mm forks but that does seem a bit excessive.
The E150 is pretty light, worth comparing weights before swtiching.
cheers - e150 comes in at 6lb so would like to shave a bit off
How about the 32 TALAS 150 15mm? Seems like a no brainer to me!
4.3lb
Maverick DUC32, 150mm and 3.7lbs
I got the 32 TALAS 150 15mm on my 575 and they are sweet.
E150 is quite light. If you change to a single crown fork, expect to feel some flex over the triple clamps...
Bike will look cool with singles on tho! 8)
