Damaged the lever on my command post. Can anyone recommend a replacement and where from? New Spesh, KS etc etc
The Thomson one is the best I've used, expensive to buy separately tho. The KS southpaw looks good too but not tried one:
http://www.stif.co.uk/mtb/product/ks-southpaw-dropper-lever-blacksilver/12303
Southpaw is ace. Stupid price though.
Ah, so are cable dropper levers interchangable then, no issues with the amount of cable they pull? Interesting...
As long as it's sprung, they actually pull the cable only a short amount, so a gear shifter is ideal if you have a dremmel to remove some of the ratchets.
It's not exactly a light way of doing things though, when the new Specialized & KS levers weigh a fraction of the weight though.
Any cheaper options than the southpaw? Interested in the shifter mod. Tell me more...
Havent done it myself. Dont really fancy taking a drill to a brand new solaris frame to put a stealth dropper in, so likely to go the KS route and mod a front shifter if I end up running 1x10/11
Shifter is working well for me
www.singletrackworld.com/forum/topic/anyone-using-a-dropper-post-with-gear-shifter-remote
nemesis' link is the one I followed to convert an SLX shifter for a KS LEV post. Running 1x10 and a LH shifter for the uppie downie seatpost is one of the best upgrades I've ever carried out.
If you're running 1x11 I can recommend the SRL that Flasheart shows above. They are available (typically order in) for an eye watering £50. If you want an original lever, I've just taken mine off to get said eye watering but really neat SRL. email in my profile.
